#1801 |
![]() Join Date: Jan 2005
Re: What did you do to your truck today.The 3rd chapter
Spent most of the weekend helping my son replace the timing belt on his Impreza. I had some time while he was at work on Saturday to weld up a speaker hole in my passenger door.
#1802 |
![]() Join Date: Aug 2011
Thank You, I'll tell him. He used to own a body shop, has done body and paint since high school and just enjoys it in his spare time. He told me he would do it if I didn't give him a timeline.
1927 Willy's Knight 24,000 original miles, 1958 Impala 283/Powerglide, 1964 C-30 383/4 speed, 1971 Monte Carlo 350/350, 1972 GMC K2500 350/350, 1976 Chev. K10 350/350, 2006 GMC Sierra 2500HD LBZ Duramax/Allison, 2006 Chev. Silverado K3500 LBZ Duramax/Allison |
#1803 |
Thank You, I'm liking it too. Can't wait to see it put together. I'll be doing that.
#1804 |
Got a new clutch fan for the 72 . Come to the conclusion the old one is engage all the time .
Hayden 2705 made in USA
Mark 72 c20 custom camper Husky edition,66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. |
#1805 |
Old member
I ordered my e-trac tie downs for the Ramp truck. I got six mounts and straps and rings to install on the sides to tie down the loads.
Plan is to drill and tap the sides to mount the singles to the bed rails. ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#1806 |
truck of four colors!
![]() ![]() Join Date: Nov 2012
Nice! Any idea as to what the weight rating is per unit?
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 Last edited by Ol Blue K20; 02-19-2021 at 11:10 PM. Reason: rephrase to avoid being an idiot |
#1807 |
Well I put my spark plug boot protectors on and worked on my fuel filler neck. The boots where a pain as they are 90 degree boots which makes putting the protectors a pain. After the first one I came up with a better way to do it. Used a wooden dowel to guide the boot through the protector. Once I did it this way the other seven were done in the time of the first one. Hope the filler neck goes this easy once the hoses arrive.
-------------------------------------------------------- 1967 C10 "Snowball" (Currently in a bazillion pieces) 1989 Toyota DLX pickup "The Hulk" 2012 Jeep JKU "Crush" |
#1808 |
I have them in my enclosed trailer except I have the full tracks front to back.one each side and one in the middle. Use them to trailer the bikes south in winter .
#1809 |
Old member
Depending on which ones you buy. I have the 1000lbs working load per each one and 4000 breaking for these. These will only be used for the golf carts and bikes.
I will have grade 8 bolts to attach the clips to the truck with. ![]()
#1810 | |
I used lots of grade 5 bolts and went thru the steel crossbars in the floor .
#1811 |
My friend got the roof and Jams painted.
#1812 |
Started a little project for the 72 .
Mark 72 c20 custom camper Husky edition,66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. Last edited by 72c20customcamper; 02-20-2021 at 10:00 PM. |
#1813 |
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 |
#1814 |
#1815 |
Mr. Cheyenne
![]() Join Date: Jun 2020
Changed the starter with a ACDelco from Rock Auto and worked on finding oil leaks as I was getting quite a few drips just sitting in the garage in idle. After getting transmission leaks fixed it was much easier to just see the oil.
I bought some Tracer Products Engine Oil dye and a uvBeast 365nm MINI - Black Light UV Flashlight. Man, that made things easier! 1. The valve covers bolts were all loose, I could likely almost have been able to remove them by hand. Used a driver to hand tighten the bolts (not a ratchet). I've read these need to be checked after re-installing the covers with a cork gasket. I'd think the shop that replaced my valve seals would have not left them loose but they didn't say anything about checking the bolts after some time either. 2. On the old pan the larger bolts were loose, to me it just seems like my brother forgot to tighten them down when switching between oil bolt sizes. The dye clearly showed oil around the bolt heads - especially on the back by the starter. So I went from quite a few drips of oil dripping just idling in place to no drips in a 30 minute idle test. Then after my test drive I dropped two dots of oil when I got back. Likely seeping coming around the oil pain at the main bearing area (at the peak of the curve it seems). I did tighten the diver side back oil pan bolt just a bit more too after all that too. The bolt head had some new oil on it (passenger side didn't). I don't think it is the main seal itself - there is no oil anywhere except for a straight down drip from the old pan. There is no oil on the torque converter/flex plate, it is dry as a bone. I tested / drove without the cover as that darn cover hides the source, so that helped too.
Richard '72 Chevy C10 Cheyenne Bronze on White [Hook 'em Horns] ![]() SBC 350 | TH350 | LWB | Buddy Seats Last edited by Rich72C10; 02-22-2021 at 10:02 AM. |
#1816 |
This may be sacrilege but I worked yesterday on converting my old oil bath breather to accept a traditional air filter element. Like it for the classic look but want something a bit less hassle. Thus far I have gotten all the old element cut out of the top cover and am grinding/sanding it smooth. Will clean it up, paint it, and determine what size WIX filter will work and be off to the races.
1967 C10 2020 Toyota 4Runner 2020 Toyota CH-R 2016 Toyota Tacoma 2012 Impala LTZ |
#1817 | |
Old member
![]() Quote:
I had the tracks in my trailer also when I had it. This is for the Ramp truck flat bed. It has 3/8" tube steel sides so I plan to drill and tap the the top and screw them in. This will only be for the golf carts & bicycles. Just to strap them down. ![]()
#1818 |
Made some headway on the console. Holes for cups are done as is the cubby . I’ll make the box for the cubby tomorrow . I made the hole the same size as a din radio so I can add it later if I decide to go that way. Vinyl isn’t glued down was just checking the hole size for the cup holders . Next I need to add the USB ports still waiting on them. Also adding a 30 amp power port
#1819 |
Installed a new heater control valve, plus reconnected with new heater hoses. Prior owner had bypassed heater core.
Not pictured, new fuel filter, cap, rotor and coil. Next up points/condenser, and plug wires. Found I had separate point and condenser and ordered a combo set. That'll teach me to order without looking first... lol Oh and the preheat tube from exhaust manifold to air cleaner.
1972 Cheyenne Super LWB, 350V8, AC, PS, PB, all original 46k survivor |
#1820 | |
Old member
![]() Quote:
Looks good by the way. ![]()
#1821 |
Just a couple of screws into the tunnel .
#1822 |
Looks good, want to see it covered....
#1823 |
I guess this fits in the "What did I do today" category. I drove the 67 GMC into work today since it's been a couple weeks. The speedometer on that truck has never liked the cold and makes some godawful screechy noises on the highway til it usually warms up and quiets down. This morning it decided to make even louder noises which I didn't think possible, the needle was whipping between 40 and 80mph before the needle broke off the base, then the base where it attached to the speedometer flew off and the screech got even LOUDER! So I did the only thing I could and went faster! Haha! It took a minute or two of this ridiculously loud howling but it finally blew something apart inside and all was quiet again. Sigh... I was actually glad cause now I know what to replace. hehe. I never knew a speedometer could make that loud of a racket. Exciting start to the day.
#1824 |
![]() Join Date: Dec 1999
Brought the old girl home after the transplant.
Smitty '71 Short Fleetside Spring Valley, Ca. |
#1825 |
