Old 02-22-2021, 12:45 AM   #1
Dodge68charger
69 C10 Bed Install Questions?
Hey Guys Im Going To Install The Bed Onto My 69 C10. Just Have a Few Questions.
Does The Front And Rear Main Sills Bolt Directly To The Frame?
No Rubber Isolators Inbetween?
Dodge68charger is offline   Reply With Quote
Old 02-22-2021, 02:42 AM   #2
pjmoreland
pjmoreland's Avatar
Re: 69 C10 Bed Install Questions?
I have never seen rubber isolators in any of the trucks I've owned. GMCPauls does sell a set though if that is the direction you want to go. Might need to add a grounding strap between the bed and frame afterward if it affects your tail lights.
https://gmcpauls.com/bed_bolt_kits.htm
pjmoreland is online now   Reply With Quote
Old 02-22-2021, 09:27 AM   #3
Peanut74
Working on my bed now. I have never seen any isolators between the bed frame and truck frame. But I do plan on putting some isolators just to keep the rattling down.
1967 C10 "Snowball" (Currently in a bazillion pieces)
1989 Toyota DLX pickup "The Hulk"
2012 Jeep JKU "Crush"
Peanut74 is offline   Reply With Quote
Old 02-22-2021, 10:52 AM   #4
Davidf
If you add isolators, you might want to consider adding same thickness shims to cab and core support. Otherwise, body lines between cab and bed are goin to be off assuming cab/core supports are in good shape, if not going to be even worse.
Davidf is online now   Reply With Quote
Old 02-22-2021, 11:13 AM   #5
Dodge68charger
Thanks Guys!
Any Tips On Installing Everything. Not Sure If Theres A Certain Order. Its a 69 c10 With a Wood Floor.
The Bedsides Are Bolted To The Front Header Panel And Rear Main Sill Already
Old Yesterday, 09:34 AM   #6
old51sedan
old51sedan's Avatar
Originally Posted by Dodge68charger View Post
Thanks Guys!
I have a 69 with wood floor. When installing floor I eliminated the bolts going through the floor into the cross members for a cleaner look. Will post a pic. Also installed the rubber shims
old51sedan is offline   Reply With Quote
Old Yesterday, 10:47 AM   #7
72c20customcamper
72c20customcamper's Avatar
I don't put the rubber insulators on mine . It's all personal preference as I see it .
Mark
72 c20 custom camper Husky edition,66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old Yesterday, 08:01 PM   #8
old51sedan
old51sedan's Avatar
I believe your right on the shims, like the color also....
Old Yesterday, 08:10 PM   #9
72c20customcamper
Could be twins .
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Thread Tools
Display Modes
Copyright ©2000 - 2021, vBulletin Solutions Inc.
Copyright 1997-2020 67-72chevytrucks.com
