06-11-2021, 01:16 PM | #1 |
1958 283 rear main leak
I have a 58 283 block with a rear main seal leak. I have never attempted this type of leak repair. Should I use the pen rope type seal or the two piece rubber seal available for this block (55-58 265/283). Also any tips are appriceated. I should add that the engine is out of the truck and on a stand. Thanks😉
06-11-2021, 09:15 PM | #2 |
Re: 1958 283 rear main leak
Napa doesn't show a rope seal for a 283/ O'Reillys does show a rope seal and or the two piece rubber seal for the 58 283.
https://www.napaonline.com/en/search...rer=plp&page=4 https://www.oreillyauto.com/detail/c...seal+set&pos=0 https://www.oreillyauto.com/shop/b/g...+main+seal+set It's been so long since I rebuilt the 283 that I had in my 48 that I can't remember what kind of seal was in it or what I put in it.
Founding member of the too many projects, too little time and money club. My ongoing truck projects: 48 Chev 3100 that will run a 292 Six. 71 GMC 2500 that is getting a Cad 500 transplant. 77 C 30 dualie, 454, 4 speed with a 10 foot flatbed and hoist. It does the heavy work and hauls the projects around. Last edited by mr48chev; 06-11-2021 at 09:35 PM. |
06-12-2021, 01:14 PM | #3 |
if the motor is on a stand, i'd loosen all the caps to replace it, imo rubber is better than rope
look for a worn or glazed finish, remove the crank and polish the oil seal surface if worn
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
06-12-2021, 02:00 PM | #4 |
I'm thinking his engine is in the truck and running.
I think I'd put on a shirt that I didn't like, pull the pan and pull the rear main and see what's in there now. I always loosen the caps on all of the mains so the crank drops a bit making it easier to change the seal. I usually check the main bearings on the engine to see what they look like too.
06-12-2021, 09:42 PM | #5 |
i should add... unless you know the condition of everything else
even if you don't rebuild the heads, rebuild the bottom end: rings, bearings, seals and timing set
06-12-2021, 09:44 PM | #6 |
you would be thinking wrong, seeing as he mentioned:
