09-13-2021, 12:14 PM | #1 |
Engine temp sensor
Before I swapped in my LT1 into my stepside. It was in a Camaro project car so I was using add on guages for the new swap to keep the cost low as reasonable.
Well I put my Stewert Warner temp guage in the cylinder head, and installed a 170* t stat with a pretty big 4 row summit radiator. The engine runs great, but the guage is always in the 220 range. Yesterday I was driving it in 90-95* weather 80mph 220* Traffic stuck in roughly 95* ambient, 220* Is the temp I am reading because of it being located on the cylinder head? I know the T stat works because the radiator is cool enough to easily touch with the electric fans going, but warms up quick when I turn them off. Ideas? |
09-13-2021, 01:42 PM | #2 |
Re: Engine temp sensor
LT1 is a reverse-flow engine. The heads receive the coolant from the radiator first, so they should in theory run much cooler. Do you have a non-contact thermometer?
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
09-13-2021, 01:59 PM | #3 |
09-13-2021, 08:38 PM | #4 |
Get a reading and see if your SW temp gauge is off. It sounds like it might be.
09-13-2021, 08:43 PM | #5 |
I spent 15 minutes blowing out the steam lines, and I know I have flow. So when I have a day off again I will verify guage function. I just restarted my new job. So I am not sure of my hours/days I work.
