Old 07-17-2015, 04:40 PM   #1
Tom
driving is in my blood
Tom's Avatar
Rear drum squeel, how do you guys make it stop????
The rear drums on my 98 have been squeeling pretty much the entire time I've owned the truck. I've gone threw 3 sets of shoes, two of hardware, wheel cylinders, and a set of new drums and having them turned all trying to get rid of it. I finally relized its the backing plate of the shoe rubbing againts the backing plate of the drum. If I put some grease in between these points I can get rid of the squeel for a day at most. I'm at the point where either my brain breaks and I murder the axle with an axe or something else manly, or I replace them with disks which I can't afford. Anyone else have this problem? Its really annoying, none of my 73-87's ever had this problem!
Old 07-17-2015, 05:36 PM   #2
Restrorob
The One And Only !!!
Restrorob's Avatar
Re: Rear drum squeel, how do you guys make it stop????
Tom,
I'd try a little Anti-Seize on the backing plate contact pads, it won't wear off or wash off in rainy driving.....
93 Jeep XJ
88 Buick La Sabra
Toys;
88 TA-GTA in the works....
97 GMC Ext. Cab
Old 07-17-2015, 08:35 PM   #3
Tom
Tom's Avatar
Do you think thats all it will take? I've already tried spray white lithium and heavy synthetic bearing grease and both wore out within a day.
Old 07-17-2015, 10:42 PM   #4
95 S_Trucker
95 S_Trucker's Avatar
Anti seize x2. I do that on every brake job. And in 30,000 miles, the anti seize is still there. It's under a little bit of brake dust, but it's still there doing its job.
95 S_Trucker is offline   Reply With Quote
Old 07-18-2015, 06:33 AM   #5
Cape Codder
Cape Codder's Avatar
I use bearing grease and mine don't make any noise. It's been almost two years since I did rear brakes.
Cape Codder is offline   Reply With Quote
Old 07-19-2015, 09:44 PM   #6
IADC43
IADC43's Avatar
Not to sound like a dick, but grease and brakes don't work well together usually.
Doesn't it sound more like a shim problem with the axle?
Matt
43
IADC43 is offline   Reply With Quote
Old 07-20-2015, 06:32 AM   #7
I doubt it's as simple as changing what you use to lube between the shoe and backing plate, if it only helps for one day using other than anti-seize.
Old 07-20-2015, 12:28 PM   #8
Cape Codder
Look for shiny spots where something could be rubbing. Any shiny rings inside the drum? Any marks on the shoes? Maybe try tightening a couple lug nuts without the wheel and see if you feel anything when turning the drum by hand.
Old 07-20-2015, 12:31 PM   #9
franken
Slightly bevel the edges of the shoes.
Old 07-20-2015, 12:46 PM   #10
Tom
Tom's Avatar
Yes, there are shiny spots. I put grease on them, or in the case of yesterday I tried anti-sieze. Stopped for a bit but the noise came back eventually.
The only thing keeping me from putting the in-expensive NBS rear disks on is the e-brake. I've been told the e-brake cable setup is different and not compatible, but nobody has told me why. Anyone know what the difference between 88-98 and 99+ is?
Old 07-20-2015, 09:59 PM   #11
God question. I don't know why you couldn't cut cable and clamp a new end on...or have them custom made.
Old 07-21-2015, 07:52 AM   #12
Cape Codder
If you have shiny spots what is rubbing to cause them? You need to eliminate the rub not lubricate it. The last thing I would do to my truck is go disc. I havn't seen a disc setup with a decent trouble free parking brake. The rears do about 30 percent of stopping and drums have worked for years. Unless you are racing roundy round or hauling heavy loads in hilly regions they are not needed and in the end will probably be more trouble.
Old 12-20-2015, 11:07 PM   #13
travlinman
Tom.
Ever find a solution to this problem? My 97 Silverado has this problem and it's driving me nuts.
94 ls swap silverado
65 Pontiac
78 c30 crew cab dually (parted and gone)
82 c30 crew cab dually ( now building )
91 r30 crew cab dually (parted and gone)
69 swb-sold
71 lab sold
all in progress......__
..........._______ |__\__
..........|__(O)______(O)] ........................
travlinman is offline   Reply With Quote
Old 12-21-2015, 12:53 AM   #14
Spastik Monkey
Anti-sieze. All I use for any brake job.
Or do a disc conversion
Spastik Monkey is offline   Reply With Quote
Old 12-21-2015, 01:27 PM   #15
Tom
Tom's Avatar
Yes I did. Stop backing back half of truck into the lake launching and picking up jetskis. Otherwise no, I get maybe a week of peace before they start up again.
Old 12-21-2015, 03:59 PM   #16
travlinman
Can pinion angle play any part ? Mine made more noise after I lowared it with a flip kit. I've cleaned everything and replaced the drums. Depending on what I do I get a couple hrs to a couple days of silence
65 Pontiac
69 swb-sold
71 lab sold
