09-20-2021, 01:52 PM | #1 |
Window sash lubrication
What are you guys using to lubricate where the rollers go in the window sash for the side glass?
I am installing new side glass in one of my blazers soon and I’d prefer to do it once and correct. Thanks Mark Will it be a problem if the sash is installed about 3/16 to 1/4 inch forward on the glass? My glass guy who is a friend just centered it and an original glass I removed from another door shows it a little more to the rear. I don’t want to make him redo it if it’s not needed. And I also don’t want to install it to find out he needs to redo it?
Click on my Not really a build thread, yet NOT SO RUST FREE RUST FREE BLAZER LS ENGINE SWAP INFORMATION THREAD BOLT RESTORATIONS 4l60 to an NP205 |
09-20-2021, 02:03 PM | #2 |
Re: Window sash lubrication
I use Dielectric grease. It seems to work well.
09-20-2021, 03:33 PM | #3 |
White lithium grease is what I always used in my glass shop.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
09-20-2021, 04:22 PM | #4 |
White lithium grease .
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
09-20-2021, 04:36 PM | #5 |
I've replaced a lot of side windows on a lot of different cars and always lubed window regulators with Valvoline synthetic grease. It sticks and doesn't get hard, even in cold temperatures. For the glass run channels, I always clean them really well and wipe on a tiny amount of silicone lube. Doing that will even make an old window work better than a new car.
09-20-2021, 06:59 PM | #6 |
Thanks gentlemen. Any thoughts on the sash placement mentioned above.
09-20-2021, 07:26 PM | #7 |
centered , about 3/4" from the edge of the glass .
