Old 01-26-2020, 10:55 PM   #1
motolover
Front crossmember swap?
I have a 1966 gmc 1/2 ton pickup and I am looking for the easiest cost effective way to get disc brakes and power steering. I have heard you can you the front crossmember from a 73-87 pickup, are Van's also the same? And input is much appreciated! Also looking to fit a 454 in but that may be a whole other can of worms!
motolover is offline   Reply With Quote
Old 01-26-2020, 11:01 PM   #2
DPowers
One foot in front of the other
DPowers's Avatar
Re: Front crossmember swap?
FAQ section has all kinds of good info.
DPowers is offline   Reply With Quote
Old 01-26-2020, 11:06 PM   #3
flashed
Im pretty sure 72 and up cross member is a direct bolt on , I plan to do one in the near future on my 65 shorty Bellsouth truck . The power steering is a little more involved but doable .
flashed is offline   Reply With Quote
Old 01-27-2020, 12:46 AM   #4
SkinnyG
SkinnyG's Avatar
'84 'Burb crossmember fit my '61, but I had to drill some holes. And if I'm going to drill holes, I might as well move the crossmember forward 1". Which I did. And section it, too.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS
1977 Silverado: Shortboxed & dropped, potato-potato
V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag
Lotus Super 7 Replica: Scratch-built street-legal rollerskate
SkinnyG is offline   Reply With Quote
Old 01-27-2020, 12:51 AM   #5
Chevy Fleetside
Chevy Fleetside's Avatar
You can bolt on later model control arms on the 63 and up trucks. You do not have to swap out the cross member.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 01-27-2020, 12:53 AM   #6
J Williams
J Williams's Avatar
I just completed a swap like this. I have a 63 C10 that I stuck a 78 C10 front crossmember in. Real easy swap, everything but 1 bolt hole on both sides of the frame matched up.
63 C10
J Williams is offline   Reply With Quote
Old 01-27-2020, 08:58 PM   #7
AcampoDave
AcampoDave's Avatar
Vans are NOT the same. They have a wider stance both front and rear.
AcampoDave is offline   Reply With Quote
Old 01-27-2020, 09:01 PM   #8
Clyde65
Clyde65's Avatar
73-87 c10, Suburban will work great!
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 01-27-2020, 09:25 PM   #9
motolover
Ok thank you guys for the very useful information I really appreciate it! So Van's wont work but suburbans will? How bout would blazers or Jimmy's?
Old 01-27-2020, 10:47 PM   #10
Captainfab
60-66 Nut
Any 1/2 ton 2wd truck based front suspension will work. So yes a 2wd Blazer or Jimmy will work. Regarding the full size vans, the spindle, rotors and calipers will work on your original control arms with a ball joint swap. The van control arms are basically the same as the C10 truck control arms, but the shafts are weird, with a tube on the outside with rubber in between. At least the set I have from a '85 G10 van are. The van steering box will not work as they are backwards from a truck box even though they look the same.
Installing a big block is not that difficult. I've done it about 28 years ago and many, many others have as well.
I do make the steering box adapter plates as well and many other products.
