11-25-2021, 05:39 PM | #1 |
Shortened Automatic tilt steering column
Shortened automatic tilt steering column for those who want a little extra room between the steering wheel & the seat. This moves the steering wheel 2” closer to the dash. It is a direct bolt in with no modifications. ( See Pictures Below ) The column was painted semi gloss black. The following parts are new, shift lever, turn signal lever, tilt lever, turn signal switch & wiring harness with correct wiring harness connector, neutral safety switch, upper & lower rubber seals, indicator lense, indicator pointer, & warning lights knob.
$685.00 plus shipping. Shipping to U.S. Only. No Shipping to Alaska or Hawaii. Payment / Personally Check or Postal Money Order Posted via Mobile Device Last edited by Don D; 04-02-2024 at 07:38 PM. |
11-25-2021, 05:46 PM | #2 | |
Posted via Mobile Device |
11-25-2021, 07:32 PM | #3 |
Re: Shortened Automatic tilt steering column
I am looking for a shortened but on the engine side if that makes sense. I added rack and pinion so I needed a bit more for that connection. Is there two ways to shorten these? May be a silly question but didn't know where it is shorter if that make sense?
I can't remember if the firewall mount is fixed or slides it's been a long time since I had mine out. Thanks Dave
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
11-26-2021, 11:18 AM | #4 | |
Don Posted via Mobile Device |
11-26-2021, 03:52 PM | #5 |
Thanks Don. That's what I assumed. I currently have the steering hooked up and working. It just has a little catch as the joint is close to the limit. I was told thebbest option is to get a shorter column. I would rather stay gm. In fact I currently have a truck tilt. I'm not sure how much is really needed. I figured the 1.5 inches would do it. Looking at my column it do see it is close now to the outer housing. Can a van tilt be shortened any more or is it the same story?
Thanks Dave
11-26-2021, 06:31 PM | #6 | |
11-29-2021, 08:14 PM | #7 |
ttt
12-03-2021, 02:59 AM | #8 |
ill take the shortened column if its still available. how exactly is it shortened? send me a PM to discuss pay. thanks
12-03-2021, 10:21 AM | #9 |
12-04-2021, 08:21 PM | #10 |
How do these columns work with say a 700R4 or 4l60e transmission, they have 4 forward gears and the pic of the shift indicator on yours only shows 3 forward gears ?
12-04-2021, 09:02 PM | #11 | |
12-04-2021, 09:47 PM | #12 |
Sounds good thank you
12-05-2021, 10:25 PM | #13 |
Anything still available here ?
1970 Chevy CST/10 1970 Chevy CST/10 1972 Chevy C/10 1972 Chevy Suburban K/10 2019 Silverado 2500 Duramax Kevin |
12-05-2021, 11:34 PM | #14 |
12-06-2021, 09:24 AM | #15 | |
Thanks!
12-06-2021, 10:56 AM | #16 |
Sent a message
01-13-2022, 10:06 PM | #17 |
Sending PM Don D
........................ ..........._____|__\___ ..........|_(O)_____(O)] |
01-13-2022, 10:26 PM | #18 |
Don,
Interested in purchasing one of your shortened columns. Do you have them on hand? How much to ship to Nebraska? Do you take Pay Pal? Any references? Send me private mail. Pappy 2 |
01-18-2022, 12:32 AM | #19 |
425hp409
If I sent you my column that came out of a van, would you shorten it and how much would that be?
Charles 68 SWB, Dad bought new, now 396 & factory ac 64 Impala SS, 409 425HP, 4 speed AC 64 Bel Air Wagon, 400 Small Block 57 Bel Air all original 283 w/Factory Air 77 GMC Sprint, 454/425HP 67 Olds 442, all original 90 ZR1 Corvette |
01-18-2022, 01:37 PM | #20 |
03-31-2024, 09:57 PM | #21 |
Do you still shorten tilt steering columns for 72 c10's ? And do you already have any done?
Bret Here's a link to my build http://67-72chevytrucks.com/vboard/s...d.php?t=577889 |
04-01-2024, 08:18 PM | #22 | |
04-01-2024, 08:25 PM | #23 |
Please Message me and I'll buy one. How much shipped? Live in Dickson,Tn 37055
04-02-2024, 07:13 PM | #24 |
I'm interested in a shortened tilt column also.
04-05-2024, 08:14 PM | #25 |
