09-13-2021, 12:31 AM | #1 |
"something witty here"
Cummins conversion questions
What fuel pump would you recommend for the 5.9 cummins conversion with factory dual saddle tanks? Im trying to gather all the parts needed for the swap before I begin.
57 chevy 4x4 70 swb fleetside 4x4 68 burb 2wd: 71 burb 2wd: 350 4spd 71 lwb fleetside 4x4: 350/sm465/205/3.07 eaton posi rear 72 lwb fleetside Cheyenne 454/th400 1991 GMC V3500 CC 4x4 |
09-13-2021, 07:55 AM | #2 |
Re: Cummins conversion questions
Check out this website for fuel consumption rates for a diesel engine. Based on these charts, even a 1000-hp diesel can be fed from a common 255 liter-per-hour pump.
The Walbro 255 is often installed in these squarebody tanks, but I don't know if it can handle diesel fuel. I assume it can, but research that first. https://barringtondieselclub.co.za/t...nsumption.html
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome! |
09-13-2021, 08:27 AM | #3 |
What did the Dodge trucks use for a fuel pump? I wouldn't think it would be in tank but I really don't know. I have always wanted to do this swap though.
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
09-13-2021, 09:58 AM | #4 |
Which Cummins are you using? 5.9 or 6.7? If 5.9, is it 12v? 24v? CR? What modifications? Intended usage? Lots more information needed
09-13-2021, 01:21 PM | #5 |
I’ve done 2 conversions a 4bt and.a 6bt both mech type engines.
make sure you read up on which style of lift pump you mate to which injection pump, the wrong one can either burn the injection pump up, or blow the seals out of it. This is related to the p7100 and the rotary ve pump, not the electronic engines
61 GMC 4x4 1-ton flatbed 4bt cummins, ranger od, sm465, np 205, d60F, d70R 4.11 10,000 ramsey PTO winch.... SOLD 73 k5 gm crate 350-265 / sm465 / np205 3.73 posi |
09-13-2021, 08:07 PM | #6 |
Sb 400 club
My 95 12valve P pump ran like a scalded dog with is factory mechanical lift pump. If i was doing the swap to keep it simple i would run the mechanical lift pump on the engine and make sure to remove the in-tank sock or put 6.2 sending uninits in your tanks.
I am assuming your running a 12 valve 5.9 with a p7100 pump. Are you running different turbo? Turbos? Auto or manual trans? Lots of factors could change what fuel pump would be ideal.
1984 chevy c10, built 400sb,.(SOLD) 77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363 1956 Willys Wagon (327 chevy) Project (Now Buick 225) 1980 Corvette L-48 4 speed 1992 Mustang GT built 5.0 5 speed 1985 C10 LWB Sold 1982 K10 SWB plow truck Parted out 1986 D30 M1028 fire brush truck Parted out |
09-13-2021, 09:12 PM | #7 | |
09-13-2021, 09:53 PM | #8 | |
09-13-2021, 10:20 PM | #9 |
You have a great platform to start with.
If it’s a 4x4 Chevy your swapping into the hardest item will be finding a pass side drop transfercase to adapt to your nv4500... Like 84 400 said, get rid on the in tank fuel sock, and do yourself a favor and replace all the rubber link fuel hoses along the frame, air leaks will drive you insane later
09-13-2021, 10:33 PM | #10 | |
09-13-2021, 11:20 PM | #11 | |
Another option to consider is to find a transfer case from a first-gen Cummins truck(pre-1994). Those were a passenger side drop, and should bolt right up to your transmission.
09-15-2021, 10:43 AM | #12 |
6>8 Plugless........
I would use the stock type lift pump especially if you want to retain dual tanks. I'd strongly recommend not installing an electric type lift pump over that piston type lift pump. (Assuming this is a P-pump 12v) Also, there is a diesel conversion section in the engine area on this forum. There's a lot of good info in there about these swaps.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
09-17-2021, 09:46 PM | #13 |
stock lift pump works for me for the last 10 or so years. fully built and flowed 215 pump.
dodge nv4500 with a chevy mainshaft, to a chevy 205 is a good way to go.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205 86 k30, 89 diesel burb, 76 gmc pathfinder 71 longbed 5.3 4l80 http://67-72chevytrucks.com/vboard/s...d.php?t=522535 |
09-19-2021, 08:47 PM | #14 |
Ok next question, will I have to cut the firewall at all?
09-20-2021, 10:05 AM | #15 |
no cutting but I do bend the firewall flange in where two of the bellhousing bolts tend to hit.
08-08-2022, 12:20 PM | #16 |
Ok I have another question. On the squarebodies do I have to cut the crossmember under the original motor out for the cummins to fit?
08-08-2022, 12:44 PM | #17 |
Everyone I have done, I removed (and replaced) the GM crossmember. You have to, to get the engine low enough to keep the drivetrain in alignment.
08-11-2022, 01:31 AM | #18 |
ok its cut out and a new one if being fabbed.
Next question. How does one hook up a tach to the the diesel? Do I need that fancy autometer gauge?
08-11-2022, 07:43 AM | #19 |
Depends on the thickness your trans adapter, but on mine I drilled and tapped the adapter for fitting a Hall effect sensor and it counted the flywheel teeth as they came by. Then I entered the tooth count equaling one revolution into a Dakota digital tach box that sent a signal to a standard tach
08-11-2022, 09:08 AM | #20 |
Over on the CUCV section of Steel Soldiers, there is mention that some alternators have a tach signal post that folks have used.
09-01-2022, 10:35 PM | #21 |
Another question for you all. What did you guys do with fuel lines to the tank? Will rubber hose and hose clamps work or no? Im also not sure which line is the return and which is the intake and help there would be amazing!
10-19-2022, 09:21 PM | #22 |
I have the truck running and driving now. But now I have a problem with my fuel line, the fuel line is collapsing while driving. I found out I bought regular fuel line and not diesel rated fuel lines so that might be one of the problems. But Im curious. I removed the sock from the gas sending unit and I was wondering if that could be causing the vacuum problem. Could it be the pickup not drawing fuel fast enough creating vacuum??
