12-09-2020, 03:36 PM | #1 |
6L80E transmission pan depth
I have a 6L80E trans from a Silverado 1500. Is there a shallow pan for the 6L80E as the truck pan is too deep for my swap application? Thanks
Kermitt's 47 truck build |
12-09-2020, 04:17 PM | #2 |
6>8 Plugless........
Re: 6L80E transmission pan depth
Here are some options I found.
https://www.hgmelectronics.com/gm-6l...nsmission-pan/ https://www.teakatoys.com/GM_6L80_6L.../pml-11087.htm https://www.google.com/search?q=6l80...hrome&ie=UTF-8
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
12-10-2020, 04:58 AM | #3 |
Thanks, I will check these out.
11-09-2021, 09:50 PM | #4 |
This is the shallowest pan I am aware of. GM p/n 24239528- made for the Caprice, SS, and G8. They are still available new and are inexpensive. Requires a matching filter- ACDelco p/n 24252158 or equivalent. Many places state they are 2 1/4" deep but that is only at the center. Like the Camaro, it has a "drain plug" that is to be used to set the fill level. I measured the volume as it sits with the top surface level. It holds 4 1/4 qts to the top of the "straw", exactly the same as the Camaro pan.
11-10-2021, 12:14 AM | #5 |
Thanks for this info, Looks like ticket.
