11-11-2021, 05:00 PM | #1 |
NP 435 shifter question
Got a question about my shifter on a New Process 435 4 speed with the granny low. I'm not sure if it's worn or if it is supposed to be this way. If I put the transmission in neutral and push it to the right in the H pattern (towards reverse but not down) I can feel that I'm pushing against a spring. If I let the shifter go it would spring back away from reverse and move toward 1-2 but still in neutral. BUT, if still in neutral and I push the shifter left (towards 1-2) just to the left, not up (1 or low) or down (2) the shifter does not spring back towards the center of the H pattern it feels loose and sloppy and you can wiggle it left and right. Is this normal or do you think something is broken?
It's not rust, it's called patina Trying to bring a 68 Panel Truck back from the dead. 396 Big Block, 4 on the floor, and a whole lot of rust. |
11-11-2021, 10:02 PM | #2 |
Re: NP 435 shifter question
Sounds like the reverse gate. It’s there to help prevent trying to shift into reverse when your moving through the forward gears.
-400/400 1979 K25 350/SM465/205/44HD/14FF 1985 K20 400/400/208/10/14 1987 V10 TBI350/700R4/208/10/10 '85 Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=643968 |
