Old 06-23-2021, 03:42 PM   #151
rodstored-72
chevy truck fan
rodstored-72's Avatar
Re: His name is "George" 84' C10
william, that is looking good. I like the tool creation too!! neat idea! it may be copied....
rodstored-72 is offline   Reply With Quote
Old 06-28-2021, 12:00 PM   #152
WilliamFd55
Thanks. I've seen ones where they used vise grips, but this way seemed easier.
WilliamFd55 is offline   Reply With Quote
Old 06-28-2021, 12:09 PM   #153
WilliamFd55
Busy weekend with work, but wanted to give it a shot on getting this thing running. Everything plumbed, fenders on, exhaust ready to shoot fire.....But this didn't happen. Couldn't get the Fuel pump to run just with the Terminator X. Hot wired it to a switch and we were good. Got keyed ignition and fuel pressure. Engine cranks, but does not start. Time to double check everything and chase the bugs. Also have to fix a minor fuel leak at the pump. Glad I went with a shut off right out of the fuel cell or it would have been major. On a good note: Finally have a hood and looks like everything fits under it!
Old 06-28-2021, 02:03 PM   #154
tinydb84
tinydb84's Avatar
Almost there!
I fought with a handful of bad sensors when I did my first fire. I managed to get TWO bad crank sensors and one bad cam sensor from the auto parts store. I thought I was losing my mind. Luckily my brother has an LS swap that I borrowed the sensors from (since I knew they were good) and it fired right up.
It wouldnt throw a code with the bad sensors because I couldnt get it running long enough. Just a thought if you cant get it to fire.
David
Instagram: myfabguy
Old 06-28-2021, 02:44 PM   #155
WilliamFd55
Originally Posted by tinydb84 View Post
Almost there!
Oh man, the one behind the starter?! Knew I should have replaced Will be a good starting point. Thanks for the info. My daughters boyfriend has a friend that does tuning. He's going to come by and see if I'm even telling the wizard the right info on the turbo? Wasn't completely sure about the timing/ psi. I've heard the MAT sensor can also throw things off. We'll see.....
Old 06-29-2021, 09:45 AM   #156
lunatic1968
Active Member
Lookin tough!
lunatic1968 is offline   Reply With Quote
Old 07-02-2021, 08:48 AM   #157
WilliamFd55
Originally Posted by lunatic1968 View Post
Lookin tough!
Thanks! Hopefully it sounds the same.
Old 07-02-2021, 08:58 AM   #158
WilliamFd55
While I'm waiting on parts and the wiz kid to come by with the laptop, I'll continue on with what I can do. Drew this pic awhile back when I had my other C10 with plans on doing it, never panned out. Going for it on this one. Started with 2014 Silverado bumper and the motto in my head of "Let's cut it up" haha. Mocked up for now with zip ties (I need to by stock in zip ties) to see how everything fits. I'll be using OEM Headlights/ housing for fog lights and they will be fully adjustable, maybe yellow?
Old 07-02-2021, 09:01 AM   #159
WilliamFd55
Should be able to do the metal work and hopefully have it bolted up over the holiday weekend.
Old 07-02-2021, 09:56 AM   #160
lunatic1968
Active Member
The bumper actually doesn't look bad, I was surprised.
Old 07-02-2021, 10:25 AM   #161
WilliamFd55
I was surprised as well. Sometimes it looks good on paper and not in reality. Still have to take it in some on the sides and its going to be raised about and inch or two. Also plan on using some round stock to mimic the two hard edges that are on an OEM 73 bumper.
Old 07-02-2021, 01:53 PM   #162
rodstored-72
chevy truck fan
I kinda like that... nice thought & good work.. will for sure be following to see how this developes..
Old 07-08-2021, 09:17 AM   #163
daddyjeep
daddyjeep's Avatar
The bumper looks surprisingly good. I'm sure it will get better as you go
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939
87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html
04 1500 crew cab
http://67-72chevytrucks.com/vboard/s...d.php?t=786514
daddyjeep is offline   Reply With Quote
Old 07-08-2021, 10:22 AM   #164
WilliamFd55
Thanks. Its going to be a good amount of metal work.....
Old 07-08-2021, 10:27 AM   #165
WilliamFd55
Small update. Didn't get as much done as I would've liked over the Holiday. Ended up being a busy FD weekend. Bumper is hanging on its own, brackets made and some nip/ tucks done. Just have to do some round bar and fog light mounts, then mud.
Old 07-11-2021, 12:53 PM   #166
lunatic1968
Active Member
What are you doing with the rear bumper? I'm anxious to see it on the ground.
Old 07-12-2021, 08:54 AM   #167
WilliamFd55
I'm anxious as well. Hoping all my measures work out. Finished up the metal work on the front bumper and starting mud. Once I have it on I'll let his toes touch the floor, haha. For the rear, currently running a stock bumper with a homemade hitch. Going to axe that and build something that has a diffuser to show more of the tank.
Old 07-12-2021, 10:48 AM   #168
lunatic1968
Active Member
Very cool.
Old 07-12-2021, 11:01 AM   #169
WilliamFd55
Very cool.
Thanks, Fingers crossed this think starts soon.
Old 07-12-2021, 11:12 AM   #170
WilliamFd55
Sneak peek at the air damn and the rod work to mimic details of the OEM bumper. Air damn is very boxy now, but will be massaged a touch.
Old 07-12-2021, 02:05 PM   #171
lunatic1968
Active Member
That will be a nice detail.
Old 07-30-2021, 10:54 AM   #172
WilliamFd55
Some pics of me possibly destroying a cowl hood, haha. Hood did not clear the turbo and from previous threads @Tinydb84, looks like venting is a good idea. Went back to the old fenders to scavenge some pieces. Plan is to install some louvers on it and will also vent the back cowl section.
Old 08-02-2021, 09:41 AM   #173
daddyjeep
daddyjeep's Avatar
I like where this is going
04 1500 crew cab
Old 08-02-2021, 12:53 PM   #174
lunatic1968
Active Member
I agree, can't wait to see more!!
Copyright ©2000 - 2021, vBulletin Solutions Inc.
Copyright 1997-2020 67-72chevytrucks.com
