Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > Vendors Marketplace
Old 02-07-2022, 04:20 PM   #201
SparkyRnD
SparkyRnD's Avatar
Re: RnD Fabrication 1963-1966 Chevrolet & GMC C10 / C20 Aluminum Radiators!
up top again
www.RnDFabrication.com
Custom Radiators, Valve Covers and Overflow Tanks
SparkyRnD is offline   Reply With Quote
Old 03-25-2022, 10:37 AM   #202
SparkyRnD
SparkyRnD's Avatar
back up top!
Old 04-22-2022, 10:21 AM   #203
SparkyRnD
SparkyRnD's Avatar
remember to ask for your discount when ordering!
Old 05-27-2022, 06:47 PM   #204
SparkyRnD
SparkyRnD's Avatar
back up again
Old 07-30-2022, 12:50 PM   #205
SparkyRnD
SparkyRnD's Avatar
up top, thanks for the orders!
Old 10-06-2022, 06:42 PM   #206
SparkyRnD
SparkyRnD's Avatar
thanks for the support!
Old 11-04-2022, 12:19 PM   #207
SparkyRnD
SparkyRnD's Avatar
back up top
Old 02-02-2023, 12:37 PM   #208
SparkyRnD
SparkyRnD's Avatar
make sure to mention you are a member when ordering to save $25 off a radiator and $20 off a fan kit!
Old 02-22-2023, 03:35 PM   #209
SparkyRnD
SparkyRnD's Avatar
back up top!
Old 07-26-2023, 10:29 AM   #210
SparkyRnD
SparkyRnD's Avatar
back up top, thanks for the support!
Old 08-22-2023, 02:27 PM   #211
RoyL
RoyL's Avatar
Looking for an LS Swap Radiator with fans. What fans come with yours? Brand, specs, etc?
What top mounting bracket thickness is needed? What's your turn around time? Thx!
Roy
1965 Suburban
Waiting on Time and Money
RoyL is offline   Reply With Quote
Old 08-22-2023, 04:55 PM   #212
SparkyRnD
SparkyRnD's Avatar
Roy
I just replied to your PM, thanks!
Old 08-22-2023, 09:17 PM   #213
RoyL
RoyL's Avatar
What top mounting bracket thickness is needed? What's your turn around time? Thx! Roy
Thanks! ~5 weeks turn-around. Can you also answer the fan specs and bracket thickness questions?
Roy
1965 Suburban
Old 08-24-2023, 11:17 AM   #214
SparkyRnD
SparkyRnD's Avatar
Sure. On the brackets, ours uses the stock brackets with the 3-core or 4-core inserts. Depending on which inserts you have, you may have to trim the rubber slightly. On the fans, we use Spal and Derale as well as a private-label fan made for us depending on your location, horsepower level, etc.
