04-29-2020, 12:56 PM | #1 |
Cab back wall carpet
Ok
How do you attach the back wall carpet to the back wall . with out the tank I am not sure adhesive will hold up well. |
04-29-2020, 01:04 PM | #2 |
Re: Cab back wall carpet
I have used quality double-sided duct tape for horizontal trunk panels with carpet. It is not permanant, but it is great becuase you can peel the carpet back off or access to clean/dry then add another strip of dbl tape and its back on. I put a peice of regular duct tape on the panel and one on the carpet, then the double sided stuff inbetween. The tape on the carpet likes to be heated with a heat gun (slightly) after it is applied and worked into the carpet backing.
I have also used 3m spray adhesive and attached the carpet to the type of very thin plywood that is used under kitchen flooring. The carpet sticks to the cut-to-fit plywood very well if done right and the panel can be removed for cleaning, given that a panel can be cut-to-fit to your liking.
He who is without oil shall throw the first rod. Compressions 8.7:1 1972 C10 1976 C10 (parts truck) 1985 K20 |
04-29-2020, 06:43 PM | #3 |
I'm working on a truck that is supposed to be original and its held on with screws.
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
