03-24-2006, 08:15 PM | #1 |
Need rear axle enlightenment
Was checking codes in a glove box on a 67 1/2 ton and found one with a listing of JO4aa SP44 G87 power lock with 3.54 gears.Then it specifically listed apart number of 3903545. So I am assumming it was some kind of special order rear end. I understand the positraction but what is the differences between that and NO-spin and Power Lock ---codes below
G80-Positraction G86-No spin G87-Power Lock
03-24-2006, 08:18 PM | #2 |
Re: Need rear axle enlightenment
A question for longhorn man.
03-24-2006, 08:55 PM | #3 |
it's a dana 44, the power-lock was only for spicer axles. i have seen a few other 67 (and earlier) 1/2 tons with a d44 rear. usually gmc's.
1969 GMC K2500 1996 Honda Accord 2007 Kawasaki KLR 650 |
03-24-2006, 11:15 PM | #4 |
72 C30 Trailer Queen
I agree. Its a Dana 44 (the sp44 stands for spicer 44).
3.54 with powerlok, a clutch type posi unit for dana/spicer rears. I have a 68 GMC C15 with a 396/TH400/dana44 3.54 (build sheet verified). It could use a posi rear (hint, hint!). I will go out on a limb here and guess that you could only get a Dana 44 rear in leaf spring configuration? Anyone have any evidence of a D44 coil rear?
Chris H 72 C30 133" 72 C30 157" flat-dump 69 C10 short fleet 71 ElCamino 2000 K2500 crewcab shortbed (sold, sorry old friend) 2005 GMC 2500HD shortcrew Duramax 2006 K1500 RCSB and a couple other projects/parts |
03-25-2006, 06:19 AM | #5 |
its all about the +6 inches
longhorn man knows nothing about this... and, that 3.54 gearing is a totally new one my me.
04-06-2021, 06:35 PM | #6 |
Found this old post and could not find any other on the subject. But the 67 GMC I am working on has the sp44 3.54 ratio but has J04AB on the spid and part number 3903540 with a 305 v6. Just wondering would this be posi[traction or no spin and what is the difference?
Thanks Russ |
04-06-2021, 07:31 PM | #7 |
The different names are a result of the branding by the different manufacturers for a clutch style limited slip differential (LSD). So a Power lock and a Positraction LSD are both the same thing but for different axle brands. And adding to the confusion a Dana 44 in a GMC had a Power Lock but a Dana 44 in Chrysler had a Sure Grip.
Even among the various GM brands there were different names for the same limited slip units. Pontiac called theirs Safety-T-Trac, where Chevrolet called it Positraction, and Oldsmobile named theirs Anti Spin. Then throw in 10 bolts that have cone style LSD and 12 bolts that are a clutch style, and depending on which piece of factory literature you refer to both styles may or may not have the same name. No wonder it can be confusing. And all that was before the aftermarket got involved. Whew! The link has more information. https://en.m.wikipedia.org/wiki/Limi...p_differential
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban the WMB,1991 S(stink)-10 Blazer,1969 GTO, 1970 Javelin, 1952 F2 Ford 4X4, 29 Model A, 72 Firebird. 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
04-06-2021, 07:54 PM | #8 | |
Thanks Russ |
04-06-2021, 08:51 PM | #9 |
I'm going to split hairs a little with the Positraction being the same as the PowerLock. Yes, they are both clutch type limited slips. The Dana diff is a 2 piece case that has "ramps" in the case that increases the preload on the side plates with power application. Probably the best clutch type LSD ever.
3.54 gears a very common ratio in Dana axles. Was the stock ratio in big block powered trucks with Dana 60 rear.
04-07-2021, 01:35 AM | #10 |
I always thought the no-spin was a detroit and the others were either a power-loc or an eaton
