06-29-2022, 09:33 PM | #1 |
1982 Chevy truck wheels
I bought a all stock 1982 chevy truck that was just parked for several years. My question is it has the factory ralley wheels. I have a nice set of aluminum wheels that would look good on it. My plan is to get it running then sell it. Should I keep the stock wheels on it or put the aluminum wheels on it.
http://67-72chevytrucks.com/vboard/s...d.php?t=548705 |
06-30-2022, 04:39 PM | #2 |
Re: 1982 Chevy truck wheels
I prefer the rally wheels.
It only has original paint once |
06-30-2022, 04:52 PM | #3 | |
But - if you go with aluminum- there will be folks lined up to take those rally's off your hands. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
06-30-2022, 06:35 PM | #4 |
Just wondering what would make the truck sell better stock or aftermarket
07-01-2022, 08:04 AM | #5 |
Advertise the truck with the choice of either wheel set. Once the truck sells, then sell the remaining wheel set.
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome! |
07-02-2022, 09:03 PM | #6 |
Tried to start the truck today and it cranked just a little then will only click. Cant turn the engine over now. Is a 305 worth rebuilding?
07-03-2022, 12:20 AM | #7 |
Nothing wrong with a 305. If it turned over and now it only clicks, sounds like the battery to me.
GoTennTitans 1987 GMC Sierra 1990 GMC Sierra (stolen) 2003 Chevy Silverado |
07-03-2022, 08:02 AM | #8 |
brand new battery and I cant turn the engine with a brake over bar
07-03-2022, 08:27 AM | #9 |
How long has it been since the engine was last run? Is there any possibility that a cylinder got flooded with fuel and hydrolocked? Pull all the spark plugs, and try barring it over again.
07-03-2022, 03:14 PM | #10 |
Just here to tinker
Yeah it sounds hydro-locked. Remove spark plugs and try again as mentioned.
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(winter unit)https://67-72chevytrucks.com/vboard/...25#post8900725 |
07-03-2022, 10:16 PM | #11 |
No fuel going to the carb. I was just trying to see if the engine would turn over. It has been sitting for 10 plus years. I pored some trans fluid down the intake and am going to let it sit for a few days and try it again.
