Old 09-26-2017, 07:03 PM   #1
Speedracer39
Speedracer39's Avatar
72 c10 flip kit/drop springs
I just installed a DJM flipkit - c notch -new rear springs on the rear and 2 1/2 drop spindles and 2"Big Block lowering springs. I currently have 245/60/15 on front and 275/60/15 on rear my plans are to put a set of 20's on it but would like to get it to sit alittle more level first. Thinking I might have to install a taller front spring any other ideas??
Speedracer39 is offline   Reply With Quote
Old 09-26-2017, 07:36 PM   #2
69 MOD
69 MOD's Avatar
Re: 72 c10 flip kit/drop springs
Can you add a 2" block to the rear?
Chad
'71 GMC 2500 Custom Ol Blue
'72 Custom Deluxe Highlander Stuffed Olive
'73 Trans Am
'13 Silverado 2500 Duramax Storm Trooper
69 MOD is offline   Reply With Quote
Old 09-26-2017, 08:18 PM   #3
71sierragrande
Petroleum User
71sierragrande's Avatar
Lower in the rear, but I like the rake too. Any more info on springs, pics?
1971 GMC Sierra Grande 2WD 1/2 ton, 350/400 auto
2008 Chevy Silverado 2WD 1/2 ton LT1 5.3L auto
71sierragrande is offline   Reply With Quote
Old 09-26-2017, 09:22 PM   #4
Mike C
Mike C's Avatar
ECE has a 1 1/2" lowering shackle for the rear.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 09-26-2017, 10:55 PM   #5
Speedracer39
The front are big block 2" lowering springs with 2 1/2 drop spindles purchased from earlyclassic the rear are new stock leafs with overload removed and DJM flip kit. Thinking I may order wheels and tires and make height adjustments after that.
