Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork
Old 02-19-2021, 11:55 PM   #1
Driver_WT
Driver_WT's Avatar
Hammer and Dolly Basics
I have slightly warped a sheet metal piece for my fabricated console (goes around the shifter and up to the dash. The weld is up the middle of the piece and it now has a slight dip in it. Can someone provide or point me to some hammer and dolly basics for getting the dip out?
Thanks.
53 Chevy 3100, SBC 355, 700R4, S10 frame, Ford 8.8 rear with 4.11 gears, front disc & rear drum brakes
Driver_WT is offline   Reply With Quote
Old 02-19-2021, 11:59 PM   #2
mongocanfly
Post Whore
mongocanfly's Avatar
Re: Hammer and Dolly Basics
heres your pic to go with your question with the bowed area
and the other thread.. http://67-72chevytrucks.com/vboard/s...d.php?t=818565
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 02-20-2021, 12:17 AM   #3
Driver_WT
Driver_WT's Avatar
Thanks for the help Greg.
Old 02-20-2021, 05:41 AM   #4
MP&C
MP&C's Avatar
Anytime you weld a seam, the weld and adjacent area which is called the HAZ (Heat Affected Zone, the area that has turned blue/discolored) is going to shrink as the weld cools. So as an example, in looking at a quarter panel side profile (red line) :
Name:  crown loss from welding.jpg
...if we were to weld a vertical seam top to bottom, as the weld cools and shrinks, it gathers up/becomes shorter in length (arrows) along the entire length of the weld. So in essence, the linear length of the weld gets shorter; it becomes a shallower arc, or towards a straight line.. (blue line) This is why ALL welds in a crowned panel, absent any planishing, will pull into a valley. The arc is becoming a straight(er) line. You combat this issue by planishing using a hammer and dolly. You want to stretch the weld to regain the linear length it was prior to welding.
For "sizing" your dolly for the concave back side, you want to match the inside of the crown as closely as possible without the corners touching. (to prevent marking/coining the metal). The convex outside of the panel you would want to use as flat a body hammer, or a slapper, etc as you have. Hold a slight upward pressure on the dolly as you hammer to coax it to move outward.
Robert
MP&C is offline   Reply With Quote
Old 02-20-2021, 09:07 AM   #5
Driver_WT
Driver_WT's Avatar
Attachment 2083119
Thanks for the explanation Robert. So do I hammer "on dolly" or "off dolly" to move the metal outward.
Old 02-20-2021, 09:45 AM   #6
mongocanfly
Post Whore
When planishing welds I do on dolley..
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 02-21-2021, 01:16 AM   #7
MP&C
MP&C's Avatar
On-dolly gives you a stretch and you should hear a ping like striking two hammer faces together. Off-dolly gives a shrink or a metal bumping without stretching.
Robert
Old 02-21-2021, 08:07 AM   #8
Driver_WT
Driver_WT's Avatar
Very helpful. thank you. I will try this today.
Old 02-25-2021, 09:27 AM   #9
Driver_WT
Driver_WT's Avatar
Thanks for all of the replies and info. I have got the console pretty much flat where the stereo will go and the rest of it looks pretty good. There is still a bit of dip in the middle at the top, but that piece will be under the dash so I am not too concerned with that part.
And I learned a bit more about hammer and dolly so thanks for that.
Wade
Old 04-11-2021, 09:29 AM   #10
Driver_WT
Driver_WT's Avatar
Got the console completed. Thanks for all of the help. I am happy with how it turned out.
