10-21-2014, 05:33 PM | #1 |
Sway bar bushing
I'm rebuilding the front of my truck and I think at some point in the past 45 years someone may have switched out the original sway bar for a thicker one.
Mine measures 1-1/16", but the bushing I got in my kit measure ~7/8". Is this correct? |
10-21-2014, 06:06 PM | #2 |
Re: Sway bar bushing
Yes, 7/8" is the standard for a C-10...But in the past few years folks have been adding the heavier sway bars. Pretty common to add a sway bar to a truck without one and if readily available using the larger bar.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
10-21-2014, 06:41 PM | #3 |
go to autoparts store and get the right size
10-22-2014, 11:24 AM | #4 |
Junior Member
The Moog part numbers are on here somewhere for the 1-1/16 and 1-1/8 bars. Be aware there are earlier (bigger) and later (smaller) style brackets for the sway bar bushings. You will need the number when you go to autoparts store.
"I was patina when patina wasn't cool." 1973 Cheyenne SWB Gold White Fleetsides/Saddle |
10-23-2014, 12:25 AM | #5 |
Sorry but I have another question.
Is the greaseable bushing a worth while upgrade? |
10-23-2014, 12:32 AM | #6 |
Moderator
The bushings for a sway bar are either rubber (OEM) or polyurethane. I am not aware of any that are greaseable
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
10-23-2014, 07:15 AM | #7 |
The poly bushings from Energy Suspension are greaseable. you grease the clamps on the frame where the bar pivots so they don't squeak at you. Mine are 1 1/16" and I always heard that was the OE small bar. I have never heard of a 7/8" bar but I'm wrong quite frequently.
Dan <---(my name) 67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car |
11-14-2014, 11:55 AM | #8 |
I went with the Energy Suspension kit with the brackets
11-14-2014, 01:13 PM | #9 |
I just bought a set of those same bushings.
Since only 2 of them are greaseable, do the grease fittings go on the frame mounts or the a-arm mounts? |
11-14-2014, 05:28 PM | #10 |
Frame. Mine came with instructions.
11-14-2014, 07:07 PM | #11 | |
11-14-2014, 09:57 PM | #12 |
I used the silicone grease that came with kit for the control arm bushings, and regular grease that I use for the rest of the chassis. The instructions said to use three pumps at the regular maintenance intervals.
07-19-2017, 12:39 AM | #13 |
So are the frame bushings and control arm bushings identical? Thanks!
07-19-2017, 04:23 PM | #14 | ||
"I ain't nobody, dork."
Yup.
Gary
