10-10-2022, 03:44 PM | #1 |
No power to cab after pushing horn button
Just like the title says. I put a set of Caddy horns on the truck a couple years ago and they have been working fine until yesterday. I pushed the horn button then all power to the cab was gone. I checked power at the fusible link junction block on the RH fender, got power from there, checked the 4 amp fuses on the ammeter circuit, they are good, got 12.5 volts at the hot post on the alternator, but that is as far as I got. The truck started fine before, no electrical issues at all. What's next, check the horn relay?
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Coming soon: EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 |
10-10-2022, 04:48 PM | #2 |
Re: No power to cab after pushing horn button
I figured out the issue. I had removed the bulkhead connector to add a power wire for efi and I didn’t tighten it back up.
