Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 08-01-2021, 09:16 PM   #1
lutronjim
Relay fuse block
I need more key switched and alway hot circuits. I keep reading that the extra goodies are working havoc on the crap switch ignition switches we get now.
I found one on Summit that gives 4 switched and 3 hot I like but it has wires from it and I would like one with spade connectors.
Painless Performance CirKit Boss Auxiliary Fuse Block/7-Circuit Kits (3 Constant/4 Ignition 12 V)
Anyone know of one with spade connectors?
lutronjim is offline   Reply With Quote
Old 08-04-2021, 06:22 PM   #2
Caddylackn
Caddylackn's Avatar
Re: Relay fuse block
Just do a search on Amazon for Marine fuse panel. Get one with the lights that go on when the fuse is blown. Very handy. I would get two, one for key on accessories and another for always hot.
I put in a six circuit fuse panel in for the key on power but I feed the panel via a 30 or 40 amp relay tied to the battree so you are not trying to run all that amps through the ignition. The relay is triggered by the stock key on power wire. I have the radio, CB, and fuel pump going to this panel. When I add my MSD ignition I will power it off this fuse panel.
1969 Custom Camper C20; Factree Air, 350/TH400/Dana 70U with C30 wheel cylinders, Disk brakes, H4 conversion, headlight relay mod, 3G 135 amp alternator. 7500 GVW
Caddylackn is offline   Reply With Quote
Old 08-05-2021, 04:52 PM   #3
Richard
A few posts down a guy had purchased one from here. https://www.online-led-store.com/fuse-boxes
Richard
