Old 07-11-2013, 11:02 AM   #12
ironroad9c1
Master Hater
Re: tranny cooler suggestions( 700r4)
Always put the biggest cooler you can find, for every 20 degrees you lower the trans fluid temp, you double the life of your transmission. problem with heat in a transmission is it hardens the rubber seals, then you get pressure leaks and then it starts slipping clutches and goes to hell from there, never hurts to install a cooler. the newer stacked type coolers work much better than the old fin and tube types.
1997 C1500 ECSB 4.3/NV3500 8.5 3.42
"This evening, all of you bleeding hearts... why don't just go ahead and hug yourself for the next 20 minutes or so, because there's a really good chance you're gonna be offended".- Captain Owen Honors
ironroad9c1 is offline   Reply With Quote
350 sbc, 700r4, transmission cooler
