Old 01-08-2012, 06:38 PM   #1
JRANGER
JRANGER's Avatar
After Market Headlight Install!!
So the first thing I bought after I got this truck was aftermarket lights of Amazon due to how horrible the stock bulbs are and to be able to swap out bulbs with ease so I finally installed them... Now it took a bit of modification.
#1 You have to modify the hole in the plate about 1/4" all around
#2 you have to cut the wiring harness into a square setup
#3 You have to move your battery to get to the passenger side
All in all it was easy and just took a little elbow greese and a sharpie lol
Anyone else have there?
Your thoughts on them?
JRANGER is offline   Reply With Quote
Old 01-08-2012, 09:49 PM   #2
INSIDIOUS '86
INSIDIOUS '86's Avatar
Re: After Market Headlight Install!!
Same headlights as matrix on summit I bought the 4x6 versions as soon as I found out I had to modify the headlight buckets I promptly returned them the h4 clips didn't work for crap and the quality was crap as well but if they work better for u with the rounds go ahead lol for an h4 swap one shouldn't have to ever cut the headlight buckets that's just poor design IMO
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 01-08-2012, 09:53 PM   #3
JRANGER
JRANGER's Avatar
Yeah I understand that and a 1/4" didnt seem like a big deal to me so I just made the cuts and it worked pretty good.....The light output seems pretty good
Old 01-08-2012, 09:59 PM   #4
INSIDIOUS '86
Yah the light output is good I assume yours came with free bulbs as well? Try running relays and sylvania silver stars if you want to try and get the max out of them. Doo at least some relays and get rid of the voltage drop from the headlight switch
Old 01-08-2012, 10:01 PM   #5
JRANGER
JRANGER's Avatar
What do you mean? I am new to these trucks so Im not sure what I need to do...They did come with bulbs
Old 01-08-2012, 10:06 PM   #6
INSIDIOUS '86
A relay is hooked directly to the battery and is basicly a bypass switch that takes power directly Colton the batter and routs it to the headlights this gets rid of any resistance from the headlight switch and firewall connections basicly making your lights brighter all your headlight switch does is turn on the relays at that point and the relays give direct power to the lights
Old 01-08-2012, 10:10 PM   #7
JRANGER
JRANGER's Avatar
o gotcha....
Old 01-08-2012, 10:15 PM   #8
INSIDIOUS '86
If you do a quick search for headlight relays in the search bar there should be a write up of how to do it
Old 01-08-2012, 10:23 PM   #9
JRANGER
JRANGER's Avatar
found it http://67-72chevytrucks.com/vboard/s...d.php?t=182351
Old 01-09-2012, 12:46 PM   #10
Pyrotechnic
Pyrotechnic's Avatar
I bought similar ones from LMC and they required absolutely no mods to the truck at all, other than re-aiming the lights afterwards. I installed a relay harness at the same time which took care of the connector problem.
1977 GMC Sierra Grande
Pyrotechnic is offline   Reply With Quote
Old 01-09-2012, 03:04 PM   #11
JRANGER
JRANGER's Avatar
nice...have you done the Relay Mod?
Old 01-09-2012, 04:08 PM   #12
silvereagle07
silvereagle07's Avatar
Check out this thread from 08. They look alot better in my opinion. They are the same lights in my wifes Patriot and the are very bright from the factory and look really nice.
Hope this helps. http://67-72chevytrucks.com/vboard/s...d.php?t=318973
Jeramy
'84 GMC project truck
'85 Chevy 4X4 SOLD
'07 Chevy Trailblazer SS
5th Annual SHPHC Car/Truck Show Pics
http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT
silvereagle07 is offline   Reply With Quote
