Old 06-01-2022, 07:43 PM   #1
zicc1835
zicc1835's Avatar
what would you do?
im going to paint my inner front fenders same color as truck should I attach the fasteners to the inner fenders and paint them truck color or leave them black with the chance of scratching the inner fenders as I attach them ...............................am I answering my own question comments please
zicc1835 is offline   Reply With Quote
Old 06-01-2022, 09:41 PM   #2
cj847
cj847's Avatar
Re: what would you do?
The speednuts attach to the outer fender, not the inner
cj847 is offline   Reply With Quote
Old 06-01-2022, 09:42 PM   #3
68 C10 Driver
Paint them and avoid the rust issue later.
68 C10 Driver is offline   Reply With Quote
Old 06-02-2022, 07:56 AM   #4
jaros44sr
jaros44sr's Avatar
They will scratch the paint ,but if you spread them open with 2 small screw drivers, they should slide over the sheet metal better
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 06-02-2022, 08:58 PM   #5
zicc1835
zicc1835's Avatar
thanks all... im going to paint them spread them attach and paint again
Old 06-02-2022, 09:03 PM   #6
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
You asked what would I do?
I would paint the inner fenders factory black.
And like mentioned above... the nuts clip on the fender lip, not the inner fender.
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 06-02-2022, 10:42 PM   #7
cj847
cj847's Avatar
I would totally abandon what you are talking about doing.
1) No part of or near the nut is visible when assembled.
2) I would not spread the clips. These things are a real pain if they don't grip properly. They are made of spring steel.
What I would do:
Have some help and lots of masking tape as you install the inner fender to keep from scratching what does show. This includes the inner fender, the outer fender, the bolts, etc.
