05-11-2022, 02:51 PM | #276 | |
Re: 53 3100 - complete rebuild and upgrade . . . .
Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
05-12-2022, 05:17 AM | #277 | |
Thanks for looking. Dan
Just playing in my shop, trying to maintain my sanity and maybe finish a project here and there. . . . My 53 3100 "rebuild" - Soon to be Scott's suspension, LS, low and mean. https://www.67-72chevytrucks.com/vbo...d.php?t=791886 My 65 Ford project . . https://www.67-72chevytrucks.com/vbo...d.php?t=792428 |
05-12-2022, 12:46 PM | #278 | |
i bet you will have plenty of room for brake and clutch pedals, i dont remember if you centered the column on the gauges or used the original notch but i have always felt the gas pedal was too far to the right away from the other pedals.
05-18-2022, 05:26 AM | #279 |
A little shiny stuff .....
More later. Dan
05-18-2022, 07:24 AM | #280 |
i love the color choice on the smooth wheels, that's going to be a great look.
05-18-2022, 11:11 AM | #281 |
Great choice of color. That will look nice next to the red.
Marc
05-19-2022, 05:07 AM | #282 |
I appreciate the input, fellas. I wanted to go a little different from standard colors and I'm digging it thus far.
Starting to play with the tunnel/ firewall a bit and getting the body parts back on to get the running boards fitted up. Goal is to have it off the chassis jig and rolling by the end of summer. More later - Dan
05-19-2022, 11:58 AM | #283 | |
Marc
05-19-2022, 12:23 PM | #284 |
Boy I wish! No, just off the jig. Still have some body work, all of the wiring and plumbing, etc to do. Just ready to get the heavy fab finished.
Dan
05-22-2022, 06:24 AM | #285 |
Got the tires mounted, so got the majority of the body back on and lined up (close enough, anyway) to check clearance, get the running boards figured and generally just get an overall feel. After studying on it, the front wheels might look a little small (but they're 18x8's with 245's?) for my goal. That might just be it sitting up in the air, though, so I'll finish the running boards and get it off the jig to see. I think worse case would be fronts with a little less back space, or maybe a small spacer will work. To me the rears are perfect.
On a different note, I've been pondering taking a little of the "bulge" out of the hood. Anyone ever take a swing at that here? Nothing to do but get back at it - thanks for looking - Dan
05-22-2022, 09:48 AM | #286 |
Nice work. JMO, but I think the front wheels look good that size.
05-23-2022, 10:04 AM | #287 |
Yeah nothing wrong with those front rims/tires from here. Trucks look weird up in the air on stands. Once you set it on the ground it will look very different. I bet your good with keeping with your current set up.
Marc
05-23-2022, 10:14 AM | #288 |
#3 here, I think front wheels look great...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
05-23-2022, 10:31 AM | #289 |
If that's at ride height, what will the ground clearance be?
05-23-2022, 04:28 PM | #290 |
Thanks for all the input, fellas. It's appreciated. I'll hurry up and get the running boards fitted and get it on the ground - I tend to agree that once it's out of the air it'll look right 😆
It's at ride height as it sits, running boards will be 5" off the ground. Thanks for looking - Dan
05-24-2022, 07:46 AM | #291 |
i think you're right ... it's not the size but the back spacing. probably looks perfect straight on, but the 3/4 angle presents the wheel/tire at a different perspective to the fender. not that it looks bad, but i think i see what you're seeing. totally fine as-is ... or an easy try-it with a spacer.
i fully support finding a spare hood and taking it to chop-town! worst case, scrap/sell it move on. |
05-24-2022, 12:02 PM | #292 | |
Marc
05-25-2022, 08:44 AM | #293 |
I think 5" ride height should be OK; I've had lower and it was fine. I don't generally stomp it around speed bumps and drive ways anyway lol 😆.
I thought about tucking a larger front wheel, but didn't want to bag it so I stayed smaller. Tucking 22s is quite a feat! As for the hood, I've been looking but they're tough to find around east TN. I do have one to go look at, but I may just go for it and see what happens one weekend if I'm feeling lucky. It's worked before! Not talking about much, just a little off the "nose" if that makes sense. Thanks for looking - Dan
05-28-2022, 02:23 PM | #294 |
Long weekend, so I figured it's time to get the old rig off the chassis jig and see it sitting on the ground. Only took a few hours to get it apart, so hopefully we can mock it up and roll it outside for a better look soon. On a side note, it's amazing how small these chassis' looks sitting by itself. More later -
05-29-2022, 09:30 AM | #295 |
Burnt a little of the midnight oil and got the body mocked up, on the ground. Exactly what I was hoping for.
05-29-2022, 09:47 AM | #296 |
Ride height looks good!
8man-aka Robert 1948 on a S10 Frame, small block with a carb 1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL] [/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204 |
05-31-2022, 09:30 AM | #297 |
Looks really good. Nice work.
Marc
05-31-2022, 02:46 PM | #298 |
Really nice, love the tuck of the rear wheels...Jim
05-31-2022, 03:00 PM | #299 |
so much win!
05-31-2022, 06:38 PM | #300 |
All - thanks for the input! I'm pretty stoked how it's gone this far. Now I'm a little more motivated!
More later - Dan
