06-08-2022, 11:50 AM | #1 |
Tired Straight-6, upgrade to V8?
This 292 struggles on grades, and I don’t mean steep grades, just rolling hills. And it gets a bit warm when cruising on the freeway. It just seems like it’s had it’s day. Not sure if I should look for a GMC V6 305 or something like a 283 or 350.
It’s a 63 C20, 292, 1bbl; T5 5-speed.
1963 C20, small window, long bed 292, 4-speed |
06-08-2022, 12:40 PM | #2 | ||
"I ain't nobody, dork."
Re: Tired Straight-6, upgrade to V8?
There will be a lot of cats that will say to keep the inline... but, you'll never have as much fun with an inline as you will with a V8. Can an inline make power like a 350 V8... sure... but you'll spend a lot of cash doing it. A 350 is easy to work on, and super easy to build power with. No brainer to me.
I'd ditch that T-5 as well... Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
06-08-2022, 01:16 PM | #3 |
If it struggles on grades are you in o/d 5th gear.
If so shift down. Get the motor back into it’s designed most efficient power rpm. Swapping to a 350 likely won’t be the wonder cure you’re looking for. |
06-08-2022, 01:56 PM | #4 | |
06-08-2022, 02:29 PM | #5 | |
The motor just doesn’t have any power.
06-08-2022, 02:44 PM | #6 | ||
If you need it to work like a truck, an SM465.
If you wanna play in it like a muscle car, an M-20/21 or a Super T-10 If you want OD, a T-56 or a TKO Gary
06-08-2022, 05:26 PM | #7 | |
Another edit: Since you're running the T5 already I would not waste the money on a gear change. The 4.10s in 5th gear equate to a 3.23 ratio. Last edited by kwmech; 06-08-2022 at 07:23 PM. |
06-08-2022, 07:36 PM | #8 | |
My 292 is the original engine, rebuilt with .030-over Badger pistons, Crane 260H cam, Rhoads lifters, oversize intake valves [1.84''], GM HEI, Offy intake, Edlebrock 1404 [500 CFM] 4 Barrel carb, Clifford headers. SM465 4-Speed, N-type crossover exhaust, 12-Bolt 3.73 rear, 235/85/16 tires on 6x16 whitespoke wheels. GMC V6s were audacious engines, but parts are scarce, and there was never a HI-Perf aftermarket. Everybody and their cousin has a V8. Your truck, your choice.
06-08-2022, 09:50 PM | #9 |
If you're going to swap, swap in a v8, not the GMC v6. It's heavy and doesn't rev high at all. Makes a ton of torque though.
I enjoy my little 283, but I have no clue what, if anything, has been done to it internally. I have dreams to build a 292 powered truck one day though. If you do choose to go v8, you'll need to swap out the passenger side frame stand from the 292 specific to the v8/230/250 inline 6 frame stand. I've got a set for the v8 that I'll trade you for the 292 set if that's the direction you choose.
Christian Carpenter 1963 C10 - Frankentruck 283, 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
06-08-2022, 10:23 PM | #10 | |
06-08-2022, 10:32 PM | #11 |
I’m going to stick with my T5 for now; not looking to do burnouts or drive it hard. It’s just a cruiser. Besides, my Ranchero transmission is getting rebuilt, so no dinero.
06-08-2022, 10:52 PM | #12 |
I can't remember, did you do a compression test on the 292?
06-08-2022, 11:05 PM | #13 |
Yes, long time ago - everything checked out ok.
I’m wondering if I should try and advance the timing a bit. Maybe that would help with keeping the temp down.
06-09-2022, 12:21 AM | #14 |
A V8 can get 20mp and have over 350hp with an overdrive transmission. The modern internal combustion engine has matured a long way since the L6's. I'm in favor of junking the old reliable and going modern. But that's just me.
Do what you enjoy and can afford. Cheers |
06-09-2022, 12:28 AM | #15 |
I would, it does help with overheating and also helps with performance. I dont know how much advance a 6 will tolerate but after a lot of reading about small block timing, (initial, mechanical, vacuum etc) I nailed it on my 283 and wow it really helped.
06-09-2022, 12:34 AM | #16 |
My old 67 and 65 both had hei’ s and I had them at 14 initial. I live at sea level.
If you live at higher elevation then your motor might tolerate a bit more than that. |
06-09-2022, 05:52 PM | #17 |
driving is in my blood
T5 is fine unless you put something with torque in there. 350 or above will shorten its life considerably. Perfect trans for the 292, or a 283 v8 though.
Personally, I'd put a V8 in it just for the exhaust noise. Anything can make decent "around town, not hod rod" amount of power.
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
06-09-2022, 06:31 PM | #18 |
I have a lot of love for 283's but if your not happy with a 292, a 283 won't be the ticket either. 283's can be spirited and fun in a half-ton shorty, but when saddled with the extra mass of a 3/4 ton long bed it won't be the same. Sometimes, when I have a heavy passenger, my stock truck's 283 can feel it.
An HEI is a great distributor and I put them in every Chevy I've ever had. The aftermarket supports them well with different counter weights and springs, adjustable vacuum advances, coils etc. Getting mine dialed in right required a degreed balancer tape, (a dial back timing light works too) which let me know my total advance, my tach and a helper to let me know at what rpm it was "all in". My total advance was low so I changed my initial timing from 12 to 16 (a huge increase from the factory spec of 4 degrees) which still kept my total advance at a tolerable level. In my case I knew I had taken it too far when the motor pinged upon lugging it a bit off idle with the clutch. (Other engines have pinged upon short shifting under heavier throttle) Geezer has previously posted an excellent article on the subject and it was very helpful along with the advice he and other "distributor doctor's" gave me right here on this site. The expression "timing is everything" holds true in life and engines. I wouldn't give up on that motor without really trying to optimize an HEI for it. Last edited by AcampoDave; 06-09-2022 at 06:35 PM. Reason: Typos |
06-09-2022, 07:20 PM | #19 | |
https://www.summitracing.com/parts/sum-850043 Guess I could try advancing the timing first, then maybe a 2bbl carb.
06-09-2022, 07:33 PM | #20 |
http://www.crankshaftcoalition.com/w...nition_advance the article that Geezer posted.
https://www.crankshaftcoalition.com/..._a_timing_tape make a balancer tape. https://www.crankshaftcoalition.com/...g_for_movement check the hub on your balancer for slippage. |
06-09-2022, 07:46 PM | #21 | |
06-09-2022, 08:04 PM | #22 | |
06-09-2022, 08:11 PM | #23 |
As you can see the original set up on my V8 was a bit vague. It didnt even have any real numbers on it.. The timing tape was way cheaper than a dial back light, it's got all the info I needed, and it looks cool too 😎.
06-09-2022, 08:22 PM | #24 |
Ultimately, that motor likes 16 degrees on the crank, the mechanical advance adds another 14 all in by 2000rpm. That puts my total at 30 which is still a couple degrees lower than other folks run, but like I said adding more to the crank made it ping off idle. The only way to get more up top was to modify my distributor which wasn't important enough for me to do it.. As a side note...my vacuum advance pulls another 22 degrees when I'm at even throttle.
Last edited by AcampoDave; 06-09-2022 at 08:41 PM. Reason: Gotta learn basic math (sheesh) |
06-09-2022, 11:01 PM | #25 |
Summit has balancer tapes for a variety of different diameter balancers. https://www.summitracing.com/parts/m...hoCY4YQAvD_BwE
