03-12-2016, 12:35 AM | #1 |
"Junkyard Dog"
Radiator date codes? What does the tag stand for?
Ok guys what does this tag represent? I have these two rad's to have restored with a new core. I'm restoring a 71 Cheyenne Super with a 350 and would like to have a "correct" tag. Both of these rad's are 3 core A/T and are identical. Any info would be great!
Thanks, Tom
72 C-10 Cheyenne Super LWB, Vortec 427,TH700, 3.73 posi, tach, tilt, AM-FM,Frame off in process. http://s289.photobucket.com/albums/l...t=7eae161e.pbw 88 Monte Carlo SS bought new only 10k miles. 73 Chevelle SS 454 had since high school. 74 Camaro Z28 350 AT numbers matching, Black on Black. 73 El Camino SS 350 4sp. 70 Chevelle SS 396 4sp, number matching with LS6 454 69 Chevy C30 Car Hauler 86 K20 383 4sp 4" lift frame off restoration. http://s289.photobucket.com/albums/l...t=1b1082d3.pbw |
03-12-2016, 01:33 PM | #2 |
"Junkyard Dog"
Re: Radiator date codes? What does the tag stand for?
Somebody must know!
03-12-2016, 02:35 PM | #3 |
Member #1049
Tom,
From my research I have found that the large font on the tag represents the "broadcast code" which was used on the assembly line to identify the radiator as a whole, I do believe this number should be on your build sheet. The smaller fonts on the left identify the end tanks used in each particular application. the numbers below those identify the radiator core assembly, Also if you wire brush the bottom lip you should be able to see the actual GM part number. Here is a link that although it does not pertain to our trucks it will help explain the coding. http://www.camaros.org/coolingsystems.shtml |
03-12-2016, 08:30 PM | #4 |
Great information!
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
03-13-2016, 10:12 AM | #5 |
As stated, the IA and OK are tank codes. I believe the IA is the driver's side and the OK is passenger side. The tanks themselves should also have the same numbers stamped into them. Between the O and K should be a smaller letter date month code. Attached is mine as an example. I have not been able to locate the IA on the driver's side, which is a much smaller tank.
03-16-2016, 10:31 PM | #6 |
"Junkyard Dog"
Livrat and geunther, Thanks! That's some good info. I'll look at my tanks. Unfortunately I don't have the build sheet on this truck. The seat was changed at sometime so the sheet is long gone.
Thanks, Tom
03-17-2016, 07:01 AM | #7 | |
K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
