Old 06-28-2018, 11:06 PM   #76
Matt_50
Re: 52 pickup 77 frame 454bbc
Sweet.
1950 Build
Matt_50 is offline   Reply With Quote
Old 06-29-2018, 01:29 AM   #77
GreasyLikeaBurger
GreasyLikeaBurger's Avatar
Originally Posted by slydogg76 View Post
Received a complete bolt kit today from totally stainless. Looks awesome!
Please let me know what you think of that kit. I am about to order it from Classic Industries and would like to know how complete it actually is for being over 3 bills. I just pulled my truck out of its stored garage after 20 years in pieces and just want an almost complete bumper to bumper kit.
GreasyLikeaBurger is offline   Reply With Quote
Old 06-29-2018, 08:00 AM   #78
slydogg76
I sure will, just by quick glance it's pretty detailed. I like how there is an individual bag for each part.
slydogg76 is offline   Reply With Quote
Old 06-30-2018, 08:58 AM   #79
slydogg76
Here's a little better view.
Old 07-02-2018, 12:27 PM   #80
8man
The bolt kit is sweet. Which kit is it? I'm looking at their PDF and I'm not sure which one it is. Thanks.
8man is offline   Reply With Quote
Old 07-02-2018, 01:19 PM   #81
slydogg76
http://www.bodyboltkit.com/1952-1953...body-bolt-kit/
This is the one that I got.
Old 07-06-2018, 10:19 PM   #82
slydogg76
More progress...third weekend in a row!
Old 07-07-2018, 08:53 AM   #83
8man
3 in a row. Wish I could do that. Good progress.
Old 07-09-2018, 09:02 AM   #84
slydogg76
More progress. Got the rest of the rusty/weak metal cut out of the way on the cab's passenger side floor area. Sanded and treated the surface rust in the cab mount and started welding in the floor panel.
Old 07-09-2018, 10:37 AM   #85
Big Daddy Bear
Big Daddy Bear's Avatar
Good job, coming along nicely!!
No bolt or nut in the world will remain tight if you turn it to liquid!!!
Big Daddy Bear is offline   Reply With Quote
Old 08-09-2018, 02:22 PM   #86
kioti79
Great build! They are always better when you build them yourself.
kioti79 is offline   Reply With Quote
Old 12-13-2020, 09:11 PM   #87
slydogg76
Over 2 years later. Still working on it, slowly but surely.
Old 12-13-2020, 09:57 PM   #88
dsraven
umm, if I could give a suggestion, I would say get a door on the opening and ensure it closes and fits the cab ok. then brace the cab on the inside of the door in an X pattern so the opening cant change shape. then you can remove the door for easy access to the cowl repairs etc. wouldn't wanna see you do all that work and then the door doesn't fit after.
Old 12-18-2020, 02:15 PM   #89
slydogg76
Thanks Dsraven, good point. I kept taking the doors off and on while checking the gaps.
Old 08-23-2021, 06:18 PM   #90
slydogg76
Additional interior cab metal work
Old 08-23-2021, 06:22 PM   #91
8man
Looking good.
8man-aka Robert
1948 on a S10 Frame, small block with a carb
1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD
Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL]
[/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204
Old 08-23-2021, 06:31 PM   #92
slydogg76
More metal work…
Old 08-29-2021, 05:28 PM   #93
slydogg76
More interior cab work. Using all metal aluminum filler to fill in the welds.
Old 08-31-2021, 08:23 PM   #94
slydogg76
More filler on interior cab. I’m not crazy on how the all metal filler spreads and trying to get the right amount of hardener before it dries. I do think it will help seal any pin holes.
Old 08-31-2021, 08:55 PM   #95
slydogg76
Old 09-05-2021, 08:09 PM   #96
slydogg76
Putting some filler on the firewall. Trying a bondo product instead of the all metal. So far I like it better. It spreads nicer and I like the cream hardener changes the color when mixed.
Old 06-13-2023, 09:25 PM   #97
Sheepdog
Sheepdog's Avatar
Hi. I just stumbled across this build. Great work! I hope you have made more progress.
I just picked up a project 51 pickup and it is on a 77 C10 frame. I think they were doing a decent job so may just keep it as is.
Keep up the good work.
Eric
Sheepdog is offline   Reply With Quote
advance design, big block, chevy 3100, frame swap, restomod
