06-17-2021, 02:00 PM | #1 |
Looking for gear shifter, turn signal, tilt lever kit
I have what I believe to be an early 80's model GM steering column in my '49 3100. I'm wanting to upgrade my steering column gear shifter, turn lever and tilt lever to an all chrome kit. Problem is, I can't find a turn lever for that kit that isn't the multi-function lever. I don't need the multi-function lever, I have a dedicated wiper knob and no cruise control. I need a simple, standard lever with the 'pin' style end that inserts and locks into the column. See pic for detail.
06-17-2021, 06:12 PM | #2 |
Re: Looking for gear shifter, turn signal, tilt lever kit
Well I made my own.
LIL ERV the 50-3600 396 BBC stroked to 415 cid Richmond 6spd over drive C4 rear Porter built a arms Never give the Devil a ride,because he'll want to Drive! |
06-17-2021, 08:06 PM | #3 |
With that column I'd have to believe that is the only way you will get a turn signal handle that is just turn signal dimmer switch flipper.
Crossfire84 is going to have to explain how to get it done though.
06-17-2021, 10:02 PM | #4 |
greyhound101 simply cut end of and tap in threads
06-17-2021, 11:57 PM | #5 |
That's what I did and it worked great. |
06-18-2021, 10:21 AM | #6 |
You're looking for a lever with an end like the top picture, but it has to be chrome and look something like the bottom picture?
77-81 G and A body https://www.ebay.com/itm/332129788503 Last edited by 1project2many; 06-18-2021 at 11:14 AM. |
06-19-2021, 10:54 PM | #7 |
06-19-2021, 10:56 PM | #8 | |
06-20-2021, 06:12 PM | #9 |
I'm wondering if that non cruise handle might be a tad hard to find in a wrecking yard. I don't think my buddy who's family owned the local Chevy dealership for a lot of years ever sold one of those G bodies without cruise and tilt.
I'd still be walking though the local pick a part looking for one to get the shaft off though. You already know how to pop it out of the switch so that part should be easy.
06-20-2021, 07:07 PM | #10 | |
06-21-2021, 08:21 AM | #11 |
The original A car non-cruise factory knob unscrewed from the lever. Maybe it's as simple as unscrewing an aluminum knob from one lever and threading it onto the other?
06-28-2021, 09:21 PM | #12 |
Done.
06-28-2021, 10:30 PM | #13 |
greyhound did you epoxy it in or just tight fit? Nice job
06-29-2021, 05:00 AM | #14 |
That looks nice. It was definitely worth the effort.
06-29-2021, 09:12 AM | #15 |
