Closed Thread
Old 12-13-2016, 06:21 PM   #1
RavageWenches
Really rusty cab..
With this being my first official post, I would like to thank everybody who has posted here on the topics of rust and how to fix it. It has really helped me out so far. But, moving on to my main issue is my 72's cab. This truck has been in the family for several years and has a ton of sentimental value so I would like to keep the original cab. This is the most rust I've seen in the roof of one of these trucks. Where should I go from this now?
RavageWenches is offline
Old 12-13-2016, 06:29 PM   #2
67ChevyRedneck
67ChevyRedneck's Avatar
Re: Really rusty cab... needing help
Holy crap!
I'd suggest a new donor roof, but with the roof that bad you really need to pull the cowl and fenders off and inspect the cowl/vent areas, along with the floor/rockers, etc.
I know you want to save it, but to save it, you may literally have to replace almost every piece of it.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline
Old 12-13-2016, 06:36 PM   #3
my56chevytruck
my56chevytruck's Avatar
ditto, I was expecting to see "rust", not rusted out. I'd agree, get a donor roof, or find a body shop that can cut the roof out and weld in a new one. then you can keep the cab. And if the roof has rusted away that much, you better look elsewhere, I'm sure you'll find more of this "rust". Good luck
RUBBER DOWN AND HIT THE ROAD!!!
1940 Ford Dlx Coupe
1969 Mach1
my56chevytruck is offline
Old 12-13-2016, 08:47 PM   #4
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
If the roof looks that bad... how are the front floor pans and rocker panels?
Man that's A LOT of rust and rot. I know you said it's got sentimental value... but in this instance, it will really hit you in the wallet unless you can do these repairs yourself. Just pull the glove box door off to keep the SPID and look for another cab.
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
GASoline71 is offline
Old 12-13-2016, 10:20 PM   #5
hugger6933
I'm in east AR. What part of TN are you in? I would cut that sucker off and add a new roof . But first you need to double check the areas like the cowl[I have a on my dolly now] that I replaced the roof due to rust and past wreck damage. The truck was all together and the owner swore the rust was not that bad elsewhere. it had upper cowl rust and some other places. I had put the roof on but then we saved the cab. If you were to find a decent donor clip roof, It could be fixed somewhat inexpensively. Jim
hugger6933 is offline
Old 12-13-2016, 10:55 PM   #6
jerry moss
Born Psycho
jerry moss's Avatar
Smile Re: Really rusty cab... needing help
i vote for a better cab, i just gave away a complete 72 GMC that had much less rust than that, you could see bubbles above the windshield. i checked with a couple body shops locally and the price to replace the roof was crazy-12+ hours labor at 150 per hour. the truck was given to me and i gave it to a friend who plans on replacing the body with better sheetmetal.
jerry moss
72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD
69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies.
73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog.
77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW
BRENTWOOD,CALIFORNIA
jerry moss is offline
Old 12-13-2016, 11:10 PM   #7
custom10nut
custom10nut's Avatar
When I saw the pictures, I figured you'd be from up in the rust belt. How did a tn truck get cancer like that? Anything can be fixed, but first sit back and ask yourself this. Would you rather spend a King's Ransom on keeping , and patching what's left of the original cab? Or get a good replacement, and finish your restoration with a lot less money spent? I empathize with you on the sentimental value, I would love to be able to have my dad's 68 GMC, but the Rust Moths did away with it some 40 years ago (I grew up in northern Michigan).
custom10nut is offline
Old 12-13-2016, 11:30 PM   #8
RavageWenches
Please note that you must be a supporting member to post classified item. This includes but is not limited to What Its Worth, Want To Buy, Want To Trade, and For Sale. Please consider supporting the forum by subscribing. Further information on the subscription levels available are located here
If you need any further assistance with that please contact any Admin for help.
Old 12-14-2016, 01:06 PM   #9
Bullcreek
Bullcreek is offline
Old 12-14-2016, 01:22 PM   #10
67ChevyRedneck
Again, you really need to remove the cowl and fenders (and even pull out the cowl/vent doors inside the cab where the kick panels are) to really assess the entire cab. A cowl replacement/repair in some respects is just as difficult/more work than replacing the entire roof.
Check these out:
http://67-72chevytrucks.com/vboard/s...ad.php?t=72472
http://67-72chevytrucks.com/vboard/s...d.php?t=421682
Here's a pic of a really nasty one:
Jesse James
Project "On a Dime"
Old 12-14-2016, 06:22 PM   #11
rob32472
There are a lot of better cabs out there in the southeast...... As others have said check it all out. I would be willing to say there is rust in other places.
rob32472 is offline
Old 12-14-2016, 06:48 PM   #12
LongBox
I would say send that cab to the recycling facility, if you can find one that recycles rust.
And, to keep the sentimental attachment, make sure the frame, or the engine, or the glove box door or something is original, and let the rest go! Trying to fix that cab is a a project I call "WOMBAT" (Waste Of Money, Time And Brains)
Rick
-69 GMC 910 Long Box, 350
-98 Chev Silverado 1500, 350 Vortec 4L60e
-08 Mustang GT Convertible
LongBox is offline
Old 12-14-2016, 07:18 PM   #13
TheCougarine
TheCougarine's Avatar
I'm not sure what it'd cost to fix but given the number of still solid trucks to be found here in east TN, I'd bet you could buy a whole other truck for the cost of replacing that roof. Theres a solid looking roller on craigslist thats been sitting for months the guy wants like 900 for. Having sentimental value I understand but unless you've got a significant amount of money you're willing to dump into it I'd look at other options.
TheCougarine is offline
Old 12-14-2016, 07:49 PM   #14
GASoline71
GASoline71's Avatar
Originally Posted by RavageWenches View Post
Cab floor is solid except for one fist sized hole on the driver side.
That's what mine had... and I ended up having to replace a big chunk of the floor boards and the kick panel. Guaranteed the lower A-pillar is rotted out to.
Not to add more misery, but there a e way better cabs out there than the one you have.
Gary
Old 12-14-2016, 09:34 PM   #15
RavageWenches
Old 12-14-2016, 10:58 PM   #16
custom10nut
Old 12-15-2016, 01:07 AM   #17
RavageWenches
Old 12-15-2016, 05:54 AM   #18
Grumpy old man
Grumpy old man's Avatar
Grumpy old man is offline
Old 12-15-2016, 08:46 AM   #19
70cst
70cst's Avatar
Folks - this is not a or Sale thread ...
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline
Closed Thread
cab, roof, rust, windshield
