Old 10-14-2021, 01:17 PM   #1
GOPAPA
"Tail Gate Best Seat In House"
GOPAPA's Avatar
I am thinking of adding glue on strips
down the sides of my truck and I am curios about the these strips staying glued on and also if any of you have photos of your truck with glued on strips .
this is photos of my truck and of another pointing out about where I would add the glue on strip
When you learn a thing a day you store up smart.
GOPAPA is offline   Reply With Quote
Old 10-14-2021, 01:22 PM   #2
Keith Seymore
Keith Seymore's Avatar
Re: I am thinking of adding glue on strips
I installed those on my red truck when I restored it in 2009.
They are still on there with no issues.
A couple tricks:
a) You have to clean the painted surface with a solvent that does not leave a residue (alcohol or laquer thinner)
b) Don't touch the adhesive of the molding or the clean area of the paint with your fingers
c) You have to push HARD. Really hard. Like in the assembly plant it would oil can the door hard.
I used a small pie crust roller to go over the moldings and make sure they were completely wet out.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 10-14-2021, 02:38 PM   #3
GOPAPA
GOPAPA's Avatar
A couple tricks:
K
Thx Keith ,,where did you get yours from ..? May I ask.. knowing where you work or worked makes me want to use your of place of reference
I will copy this and keep it ..
Old 10-14-2021, 05:38 PM   #4
TKCR
TKCR's Avatar
Mine were done from the PO, in the early 2000’s. I’ve had the truck going on 8 years, and they are still holding strong.
Old 10-15-2021, 09:51 AM   #5
GOPAPA
GOPAPA's Avatar
Great color and very nice looker ,, like to see all photos of it .. Are they on this site somewhere for all to see ?
That' exactly what I want to do to mine,, but will wait until next summer when it is warmer ..by the way mine is being picked up today and will be in my garage on a day or so ..
Old 10-15-2021, 10:30 AM   #6
TKCR
TKCR's Avatar
I have a build thread. The link is there on the bottom signature
Old 10-15-2021, 08:52 PM   #7
GOPAPA
GOPAPA's Avatar
I looked at it ,, Wow! about as good as it gets .. amazing how some people can turn a truck into a gold mine to see and one worth a gold mine to own.. my 71 was a looker .but up close it had it's bad things ,, congrats on your truck TKCR
Old 10-16-2021, 09:33 AM   #8
TKCR
TKCR's Avatar
Thank you
Old 10-16-2021, 12:05 PM   #9
LT7A
A couple tricks:
K
Keith, did you buy a roll or a pre-cut set? Glad to see this thread since I will need to do it too.
Old 10-16-2021, 12:43 PM   #10
GOPAPA
GOPAPA's Avatar
I looked the stripping up and seen it was around a $100 and it is already cut in 14 pieces .
If you buy a roll then you will have to buy a special cutting knife that cuts on an angle
As for me I will buy the already cut pieces
Old 10-16-2021, 07:43 PM   #11
Keith Seymore
It was pre cut.
I got it from one of the usual suppliers: LMC or Classic or someone like that.
K
1979-1986
1986 - 2019
Old 10-19-2021, 01:13 PM   #12
Jeepwm69
I just wish someone made the High Sierra/ Scottsdale trim.
They made a "sort of" trim, but I got samples and nothing matches the OEM rear corners that are still on my truck.
Jeepwm69 is offline   Reply With Quote
Old 10-19-2021, 07:55 PM   #13
GOPAPA
GOPAPA's Avatar
That's not right of any of them ,,I thought LMC made all things for both ,, darn it.
I was wanting to buy the cut already trims for my truck but then noticed that the guy or so before me done away with the side gas tank door openers and put the tank under the rear ,, and so not more doors to use the small rails pieces ,, I would now have to buy a roll and the bevel cutter and do my own,,
Old 10-21-2021, 05:49 AM   #14
LT7A
I'm going to buy a roll and cut it on a chop saw. Cut it face down and go slow and it should come out great.
Old 10-21-2021, 05:51 AM   #15
LT7A
That's the textured black, with the chrome plastic strips top and bottom, right? I found that somebody made that 4 years ago or so, but I don't remember who it was. I need that stuff for my other truck, so if you find it, let us know.
Old 10-21-2021, 08:45 AM   #16
GOPAPA
GOPAPA's Avatar
What blade do you use :plywood blade"?
Old 10-21-2021, 01:17 PM   #17
wazzabie
The problem I see with the glued on trim strips is that over time rust happens behind the strips. At least that is what happened to the originals.
wazzabie is offline   Reply With Quote
Old 10-21-2021, 01:36 PM   #18
Jeepwm69
https://67-72chevytrucks.com/vboard/...d.php?t=583306
I started a thread about it back in the day. Still have trim corners and nothing else on my truck, but I've been focusing (on and off) on the interior lately.
Old 10-22-2021, 01:34 AM   #19
farmall
farmall's Avatar
All the CL adds I see from the wet side of the Cascades have rust in and around the trim. The moss and lichen starts to grow in there and then its over.
The trim looks great but my K30 will not have trim after getting painted and the Jimmy will get it removed. They are not garage queens.
1955 GMC 250 8 Flatbed
1971 C30 157" 350 4spd 10' Flatbed
81 GMC K30 CnC 9' Flatbed 454 T400
89 GMC Jimmy Stock https://67-72chevytrucks.com/vboard/...d.php?t=810958
71 LT1 Convertible, 72 Coupe
69 CJ5, 75 CJ6, 67 M715, 72 M35A2 Bobbed, 95 XLC2
farmall is offline   Reply With Quote
Old 10-22-2021, 07:21 AM   #20
GOPAPA
GOPAPA's Avatar
Here in Idaho it is pretty dry climate ,,You are correct about moss and lichen the other side of the Cascades ,,it is not nothing here like where I lived 45 miles from the Pacific Ocean..
Old 10-22-2021, 09:03 AM   #21
blazer2007
can you re-glue old strips that are falling or have fallen off ?
blazer2007 is offline   Reply With Quote
Old 10-22-2021, 01:15 PM   #22
wazzabie
mine are so delaminated I would not see how. plus the rust issue they cause. after repaint they are staying off
Old 10-22-2021, 02:23 PM   #23
hooverfish
hooverfish's Avatar
I used a utility knife with new blade to cut mine. Used a metal straight edge as a guide, no problem to do angles too.
I would recommend buying the roll of trim instead of precut. You will have plenty left over which is good if you need remove a crooked piece and/or redo a piece.
Larry
84 Chevy SWB, "Roy", dark blue orig paint, 6 cyl auto, PS, 88,000 miles.
72 Highlander LWB "Olive" med olive over lt yellow, air, 77,000 miles (sold)
"It's a sorry man who can't find his wife a good job"
hooverfish is offline   Reply With Quote
Old 10-22-2021, 03:23 PM   #24
GOPAPA
GOPAPA's Avatar
Yeah I have to use a roll as precut is when you have gas tank doors and mine are both gone and smoothed over .
They make a special tool for cutting the beveled edges too.. maybe buy one maybe not ??
Old 10-22-2021, 05:09 PM   #25
hooverfish
hooverfish's Avatar
I dont think you need that tool to cut, trim is cut easily with sharp utility knife.
Check out this video by Kevin Tetz with LMC, it helped me a lot.
https://www.youtube.com/watch?v=ffYSF-9dHdo&t=1001s
This install is not that hard, dont be intimidated. Take your time on the first few pieces, you will do just fine.
Larry
