Old 01-07-2016, 07:37 PM   #1
Gary 70 Jimmy
Gary 70 Jimmy's Avatar
rear hitch spare tire holder
i have a jimmy with a popup camper on it dont like the spare tire on the front does any one have pictures of a spare tire mounted in the rear hitch.
1972 GMC Jimmy 1/2 4X4 4wheel camper
1970 GMC Jimmy 1/2 4X4 350
1969 Chevy Blazer 1/2 4X4 307
1967 chevy LWB 3/4 396
Gary 70 Jimmy is offline   Reply With Quote
Old 03-14-2016, 09:05 PM   #2
Gary 70 Jimmy
Re: rear hitch spare tire holder
ttt
Old 03-14-2016, 09:56 PM   #3
Thanos
Thanos's Avatar
I just took apart the entire assembly of the rear hitch spare tire crap under my truck ,if you were in the area I would give you all of it heh. Dropped the spare and all.
It's basically just 2 long bolts that slide into a flat bar,they are held by the frame.
Thanos is offline   Reply With Quote
Old 03-14-2016, 10:03 PM   #4
MikeB69C10
MikeB69C10's Avatar
Here's mine without the spare.
MikeB69C10 is offline   Reply With Quote
Old 03-14-2016, 10:06 PM   #5
Thanos
Thanos's Avatar
That's the one! Had to cut the bolts out. Custom fuel tank going there!
Old 03-15-2016, 12:41 AM   #6
swamp rat
swamp rat's Avatar
Got a pic of how it was mounted on the front?
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 03-15-2016, 01:03 AM   #7
mike16
too bad you chopped up the hardware. some of it is unique and typically not available through vendors or Ace hardware stores.
mike16 is offline   Reply With Quote
Old 03-15-2016, 07:13 AM   #8
I think what is on his mind is a tire carrier made to mount in a 2" receiver. This is a K/5, no under body tire carrier where the gas tank is
Old 03-15-2016, 07:33 PM   #9
Gary 70 Jimmy
You are right in the 2" receiver hitch. thanks Tim
Old 03-15-2016, 11:03 PM   #10
Thanos
Thanos's Avatar
Yep however I am building a 72 the way I want it.The original location of the fuel tanks is stupid in every way of engineering and extremely unsafe.
Custom fuel tank and class V hitch going around it is far better use of space than for a spare.
Old 03-15-2016, 11:52 PM   #11
72MARIO
72MARIO's Avatar
This is a option expensive new but it works great . Its made by tire gate
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 03-16-2016, 07:40 AM   #12
That's your opinion. An opinion with no facts behind it. These trucks have superior engineering through and through, which is why they are still great daily drivers today. The proof is in the pudding. Hundreds of thousands of these trucks, as well as years prior, with tank in same location. Where are the stats to back up the unsafe position of the tank? Can't base it on a 40+ year old corroded tank, either. A leaking tank placed anywhere in the vehicle is unsafe. When we choose to drive 40+ year old vehicles we choose to either put them back to proper condition or take our chances.
Old 03-16-2016, 12:21 PM   #13
CCCC
CCCC's Avatar
Excellent post.
CCCC
67 Sting Ray Coupe 327 4sp; 68 K10 Suburban 327 4sp; 69 K20 Lifted 383 4sp; 69 C80 Fire Truck 478 V6 5sp/2sp; 69 C20 Longhorn 327 4sp; 70 C30 Wrecker 350 4sp; 70 C30 Flat Bed 350 4sp; 71 C20 LWB 350 4sp; 72 K5 Blazer 350 4sp; 72 C30 Flat Bed Gooseneck Hauler with sleeper 350/TH400; 72 C20 Longhorn 402 4sp; 52 Mack LTL Supercharged Cummins 5sp x 3sp; 01 Dodge 5.9 HO Cummins 6spd; 02 Safari Trek 2430 8.1 Vortec on Workhorse Chassis; 03 Silverado 2500 HD 4wd Duramax/Allison
Moved but still in the family
70 C20 Custom Camper 350/TH350; 72 K5 Blazer CST Highlander 350/TH350
Recently sent to new homes
72 C30 MoHome 402 4sp; 72 K5 Blazer Conv 350 4sp; 75 GMC 6000 Aerial 350 w Allison; 72 GMC 3500 Utility 350 4sp; 70 GMC 3500, 350 4sp
CCCC is offline   Reply With Quote
Old 03-16-2016, 03:31 PM   #14
cleszkie
cleszkie's Avatar
Gary,
I too have a Four Wheel Camper on my Blazer. I was also stumped as to how I would carry my spare tire, as I don't even have a front mounted spare carrier. I initially used a hitch mounted spare carrier made by Reese, but it ended up being a PITA because I had to remove it to open the camper rear door, and it prevented me from hauling my trailer/boat/etc, because the receiver was being used.
I considered modifying the fiberglass half top and rear of camper so I could slide it forward enough to mount my tailgate and use my old swing-away tire carrier. But I didn't want to screw up the camper. So I ended up fabricating a mount for the swing away carrier to attach to, in lieu of the tailgate mounting point. It allows me to use the swing away tire carrier, open the camper door, and keep the hitch available for towing. I did have to make a small cutout in my rear bumper to install the new mounting point, but the new mount is totally removable from the vertically mounted 2" receiver hitch I welded to the frame rail behind the bumper. I also had to make minor modifications to the swing away carrier to make the connection point line up with the frame mounted mount I fabricated. As added precaution to prevent slop between the mount insert and the vertical 2" receiver, I drilled two holes on adjacent sides of the receiver, welded on 3/4" grade 8 nuts, and tighten the two grade 8 bolts through the holes until them are tight against the insert. I will get pictures soon. I am at work and my Blazer is out in then parking lot. Pictures will make more sense.
cleszkie is offline   Reply With Quote
Old 03-16-2016, 04:09 PM   #15
cleszkie
cleszkie's Avatar
Pics:
Old 03-16-2016, 04:10 PM   #16
cleszkie
cleszkie's Avatar
More pics:
Old 03-16-2016, 06:30 PM   #17
Thanos
Thanos's Avatar
http://www.autosafety.org/history-gm...s-tank-defect/
They were recalled for fuel tanks catching on fire in a side impact collision.
The tank behind the seat is yes IMO ****ing stupid.
I prefer the look of classics with some modern updates so yes I bought my truck so it's what I do with it, do with yours as you please. Take your "pudding" and give it to somebody else.
Old 03-16-2016, 06:39 PM   #18
cleszkie
cleszkie's Avatar
Can we get this thread back on track for the sake of the originator? Hotheaded newbie rants will get this thread pulled by the admin. Thanks.
Old 03-16-2016, 06:58 PM   #19
Thanos
Thanos's Avatar
Was attacked first, didn't want to derail.
Old 03-16-2016, 07:49 PM   #20
Gary 70 Jimmy
cleszkie, I was going to do the some thing I have the tire carrier just need the inner brackets for the quarter panel. That looks perfect the way you did it. thanks for help Gary
Old 03-16-2016, 08:30 PM   #21
2manycars2littletime
Thanos,
FYI; That recall was for the 1973-87 trucks with the side saddle fuel tanks, not for the cab-mounted tanks in the 67-72 trucks.
Keep your head up...and your stick on the ice.
2manycars2littletime is offline   Reply With Quote
Old 03-16-2016, 08:56 PM   #22
Thanos
Thanos's Avatar
Keep your original tanks /shrug however keep the thread on topic.
Old 03-16-2016, 09:43 PM   #23
Gary 70 Jimmy
My tire carrier is longer and has the jerrycan hook up.
Old 03-16-2016, 09:46 PM   #24
Gary 70 Jimmy
Some people need to delete their post on my thread they do not help me out at all. Make your own thread. Thank you
Old 03-16-2016, 09:47 PM   #25
cleszkie
cleszkie's Avatar
Shouldn't matter. You have to move the mounting spar on the rack to line up with the new mounting post. However, the longer rack will put the weight of the tire farther away from the new mounting post position and may cause flexing. If you rack is long enough to span the rear door opening, locate the new mounting post on the hinge side of the door instead.
BTW, I retained the original mounting spar on my rack so it can still be used when I remove the camper and replace the tailgate.
