09-12-2020, 02:43 PM | #1 |
Proportioning Valve Recommendation
The only part of my brake system I haven't replaced is the proportioning (combination) valve, and I figured I might as well do that before I bleed the system. I've looked through a number of posts, and seen that the aftermarket brass ones tend to leak. The recommendations I've seen on the board are the Wilwood 260-11322 and the Inline Tube (no part number given).
If any of you have firsthand experience with either, I would love to hear about it. Thanks.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
09-12-2020, 03:18 PM | #2 |
Re: Proportioning Valve Recommendation
I bought mine from inline tube. Customer service was very helpful.
Prop/combo valve will be different for 4 wheel disc is added rear Disc 4 wheel drum Front disk/ rear drum
My build page http://67-72chevytrucks.com/vboard/s...d.php?t=764662 My cabinet building site http://www.cbcabinets.com |
09-12-2020, 07:48 PM | #3 | |
Was it the PR102? That's the one listed for 71-79 with front disc/rear drum brakes. Did all the fittings line up?
09-12-2020, 08:02 PM | #4 |
I'm trying....
I have not used these guys...but I have talked to them on the phone about rebuilding prop valves. They seemed like a good option, so I banked the info. They specialize in Corvettes. Before I found an NOS valve for our last build, I was planning to send an OE one to them for rebuild. Perhaps an option.
https://www.muskegonbrake.com
1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076 1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352 1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290 1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555 "Sometimes I wonder if zander208 was even real..." |
09-12-2020, 08:14 PM | #5 |
Thanks. I'm wondering if I'm in the "if it ain't broke, don't fix it" dilemma.
