02-07-2017, 10:15 PM | #1 |
power steering pump question
I bought a new chrome ps pump off ebay. And my old grimy one worked better.
Are there different kinds of pumps. Like different power ratios etc.? The steering drags when i just start it up. Once I get rolling it smooths out. Thanks in advance. |
02-07-2017, 10:25 PM | #2 |
Re: power steering pump question
Loose belt or air in system are 2 possibilities.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Coming soon: EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 |
02-07-2017, 10:30 PM | #3 |
Not an expert here by any means but from what I have seen lately for either a rack and pinion upgrade or PS is that there are different pressure and flow requirements for different vehicles
02-07-2017, 11:03 PM | #4 | ||
"I ain't nobody, dork."
Jack the front of the rig up and with the truck running turn the steering wheel lock to lock about 4 dozen times. It will help to bleed the air from the system.
Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
02-08-2017, 11:23 AM | #5 |
Did you get the correct pump for the app? If I remember right some pumps have different pressure outputs and can be adjusted. I don't remember how they are adjusted.
Could also be a bad pump never know what you get off ebay.
68 c10 swb stepper 68 c10 swb stepper 67 c10 lwb 06 gmc duramax |
02-08-2017, 01:18 PM | #6 |
To be honest I didn't know there were different pressures for different applications.
I will call to check on that. I did rotate the wheels back and fourth alot. It is only when its cold and im pulling out of the garage. Thanks for the input |
02-08-2017, 02:20 PM | #7 |
I used this kit to reduce the pressure going into the pump because my steering was too easy, however you can also increase the pressure with kit. Easy install also
1970 C10 Short Stepper with 71/72 front clip. Last edited by BugzC10; 02-09-2017 at 08:48 AM. |
02-08-2017, 05:59 PM | #8 |
Learned something new today. Power steering pumps vary in pressures.
I will probably just go buy a pump with the right pressure. That way if the one I have is bunk. Im done. |
