08-09-2013, 10:48 PM | #1 |
1986 Dana 60 help.
While tearing down my Dana 60 on my 86 1 ton GMC i came across some parts I need to replace. The problem is that this part is not on any of the exploded diagrams and I need to know what it is and where i could get another one.
Delco still makes the backing plates and I have a part # for them. This piece does not come with the backing plate. This is like a dust shield and slides on after the backing plate. My Dana 44 has the backing plate and this piece as one casting. Any help would be appreciated. Steve.
1977 K10 6ft Stepside L6 1978 C10 8ft Stepside 400 1980 C10 8ft Widebox with Uncle L6 1986 K35 Not a dually 350; 79 K20 Stripped 1973 and 1976 Chevy Truck Trailers 1995 Impala SS LT1 |
08-10-2013, 07:00 AM | #2 |
Next!
Re: 1986 Dana 60 help.
That looks like a dust shield without the surround. Group 5.002 part 463813 and 462814
is what the GM parts book shows.
86 K30 CUCV M1028A1 86 K30 CUCV M1028a2 dually 86 K30 C&C 6.2 4:56s, 4M, 11,000 gvw, ex fire truck, now lowboy dump More square bodies and CUCVs than I care to admit to 2020 Silverado K3500HD Work truck |
08-10-2013, 07:13 AM | #3 |
Those are the number for the dust shield. What this does is it goes on on top of the dust shield.
Those part numbers are not for this.
08-10-2013, 09:37 AM | #4 |
Next!
Just had one of my trucks apart for calipers rotors and pads, it didn't have what you're looking for.
08-10-2013, 09:46 AM | #5 |
Junior Member
Step side man, I am in the middle of COMPLETELY rebuilding my Dana 60 and one of those shields on mine is corroded also. I'm on the hunt for some and when I find anything out ill let ya know.
1969 impala conv 427 #s loaded. dad bought new 1969 "Judge" RA-3, rare warwick blue/white, #'s 1968 vet convertible #s 427/435 tripower (sold) 1968 belair 2door post #s 427/385 1936 ford 5w coupe dads 1st car 1969 camaro ss (17,xxx) miles Wanted: 69-72 suburban project, 69 camaro convertible. also any big block cars. 69-70 gto judge project. |
08-10-2013, 10:20 AM | #6 |
68 stepside 76 blazer 86 Silverado 07 Sierra Z71 17 Max Trailering 6.2 Crew 71 Nova SS My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=363634 |
08-10-2013, 10:31 AM | #7 |
That pirate link tells me nothing. I know what they do, I took them off. What I need to know is where to get new ones. And I am apparently not alone.
08-10-2013, 10:35 AM | #8 |
08-10-2013, 11:14 AM | #9 |
lmgtfy_com.htm
08-10-2013, 11:30 AM | #10 |
08-10-2013, 12:23 PM | #11 |
Mud slinger maybe? Aftermarket available only as a press-on fit:
$2.50 per at: https://www.4wdfactory.com/store/pro...2C-Mud-slinger |
08-10-2013, 12:34 PM | #12 | |
08-10-2013, 12:48 PM | #13 |
08-10-2013, 01:36 PM | #14 |
I have seen that exploded view before. The location of that piece is incorrect in the drawing. It does not go between the spindle and the knuckle. It actually belongs between 63 and 64. It is also facing the wrong direction. That part number i believe starts 1400XXXXX. I could not find any info when I googled it.
08-10-2013, 02:29 PM | #15 |
http://www.billavista.com/tech/Artic...nt_Axle_Bible/
part way down the page CHEVY DANA 60 exploded view #56 PN# doesnt seem to come up as the right part though
68 stepside 76 blazer 86 Silverado 07 Sierra Z71 17 Max Trailering 6.2 Crew 71 Nova SS My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=363634 Last edited by russgt; 08-10-2013 at 02:37 PM. |
08-10-2013, 03:06 PM | #16 |
http://coloradok5.com/forums/showthread.php?t=283576
Call Boyce equipment, they stock them. http://www.boyceequipment.com/
08-10-2013, 04:11 PM | #17 |
Now we are talking!!!!
Exactly right. I will call them Monday.
08-11-2013, 01:11 PM | #18 |
If anyone else has any idea where to get these that would be great.
08-13-2013, 09:23 PM | #19 |
What did boyce have to say?
08-13-2013, 09:40 PM | #20 |
Boyce does not have any. Back to square one.
08-17-2013, 08:40 AM | #21 |
Anyone else have any ideas on this?
08-17-2013, 09:53 AM | #22 |
ive seen them alot worse, do a little repair job... cut out a strip and weld it on, if you cant weld use shallow rivets.. just an option.
08-17-2013, 04:32 PM | #23 |
Next!
http://hillbillywizard.com/
Give them a shot, you never know
08-18-2013, 11:19 AM | #24 | |
I wonder why the exploded view is so wrong? Nothing goes on before the spindle.......plus it's backward. Makes no sense?
In reality though, you could just leave them off. It really only "slightly" blocks debris from getting behind the hub. It is not a "seal" or sealing surface, so mud and water can still get in there. I wouldn't worry about it.....and I sure would not go to great expense to get them.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. |
08-18-2013, 11:49 AM | #25 | |
Tags |
1 ton axles, dana 60 |
