Old 02-28-2011, 11:51 AM   #1
es67chevy
es67chevy's Avatar
Help Me Identify This Part - Hint: It was under the dash
OK folks. Time for another round of "Identify my part". Found this attached to the firewall with nothing plugged into it. Can you tell me what it is?
Eric
1967 C10 SWB
383 Stroker/TH400
Brother's One Piece Power Windows
Shaved Doors, Markers, and Bumpers
4/6 Early Classic Drop
Rear Fuel Tank (49-52 Chevy Car Tank)
Surf Blue Paint
Bella Vista, AR (Arkansas for those that get the 'A' states mixed up)
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=330869
es67chevy is offline   Reply With Quote
Old 02-28-2011, 11:55 AM   #2
DeputyDan
Re: Help Me Identify This Part - Hint: It was under the dash
Is that the horn relay? When I replaced my horn that is what mine looked like. If you dont have a horn and you push the horn button you will hear it click.
DeputyDan is offline   Reply With Quote
Old 02-28-2011, 11:55 AM   #3
Transformula
Transformula's Avatar
Looks like a horn relay.
T.Y.N Custom Works..... Because "Stock" Sucks!
1971 K 10 GMC Long Bed
1977 Formula T/A Frame off Resto-Mod
1995 FXDL Harley Low Rider
1985 C10 ShortWide 91 Burb front.
Transformula is offline   Reply With Quote
Old 02-28-2011, 12:01 PM   #4
es67chevy
es67chevy's Avatar
Man, that was fast. Much appreciated, fellas. Now, I just need to figure out how to hook it up.
Eric
1967 C10 SWB
383 Stroker/TH400
Surf Blue Paint
Old 02-28-2011, 12:34 PM   #5
c10/72
c10/72's Avatar
Thats a horn relay...had the same one on mine...still have just no horns!
c10/72 is offline   Reply With Quote
Old 02-28-2011, 01:31 PM   #6
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
It's electrical....
Member Nr. 2770
Old 02-28-2011, 02:22 PM   #7
Tkmadone
Looks like the heater/AC fan high speed relay to me.
Tkmadone is offline   Reply With Quote
Old 02-28-2011, 05:27 PM   #8
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
if it was on the drivers side, then it is for the horn. Look for a 3 wire plug hanging there, red green and black if not mistaken.
If on the passenger side, then it is the high speed blower relay.
Old 02-28-2011, 10:04 PM   #9
dmack91
dmack91's Avatar
Just hooked mine up last weekend. It isn't attached to the firewall, but hanging right beside the steering column near the firewall. Horn relay.
The heavy green wire should come out between the driver's side headlight and radiator (mine had been cut off near where it came out of the harness there).
No horn when I got it, but that relay was hooked up and you could hear/feel it clunk when hitting the horn button.
68 Chev C20- son has it now
83 K20 - bought from son
70 C20 - in progress
dmack91 is offline   Reply With Quote
Old 02-28-2011, 10:41 PM   #10
mr48chev
mr48chev's Avatar
If you found it slightly above and to the left of the steering column it is the horn relay. If it was unhooked I'd think that either it stuck, the horn button or wire to it is stuck or shorted or the horn stuck on.
Old 03-01-2011, 07:08 PM   #11
48richard
48richard's Avatar
Another possibility is the anti-dieseling relay, if you have A/C. This goes to the right of the A/C controller, with orange, pink, and green wires
1971 C10 Longbed, 350/TH350
48richard is offline   Reply With Quote
Old 03-01-2011, 11:55 PM   #12
es67chevy
es67chevy's Avatar
We didn't have a working horn when we bought it and it is not an A/C truck so I'm leaning towards horn relay. And I don't think we will need it for our build because we're using a Painless Wiring setup that doesn't appear to use a relay (Someone correct me if I'm wrong here).
I knew I should have documented where we took it off from. I'm pretty sure it was to the left of the steering column. I'll try to find some pics of the firewall that we've taken and see if I can identify where it was mounted.
Thanks all!!
Eric
1967 C10 SWB
383 Stroker/TH400
Surf Blue Paint
Old 03-02-2011, 12:03 AM   #13
tcb-1
Nothing to see here.....
tcb-1's Avatar
a thingamabob
Doug
THANK YOU to our American Soldiers & Veterans - POW MIA "You will NEVER be forgotten".
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson
tcb-1 is offline   Reply With Quote
Old 03-02-2011, 12:43 AM   #14
es67chevy
es67chevy's Avatar
Originally Posted by tcb-1 View Post
a thingamabob
Hahaha. I have a lot of 'those' left over from this build. Plus a few missing thingamabobs.
Eric
1967 C10 SWB
383 Stroker/TH400
Surf Blue Paint
Old 03-02-2011, 02:35 AM   #15
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Here's a couple of locations.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 03-02-2011, 02:50 AM   #16
wwotr
wwotr's Avatar
I remember mine went bad in the middle of the night.
Like 2AM!
Horn started BLARING!
I went out in my pj's and yanked the spade connector off the Horn.
"That'll fix it"...I said to myself.
Next morning I had a Dead Battery.
(come on guys, it was 2 in the morning , out of a DEAD SLEEP)!
Hello members...
I'd like you to know that I sold,
my 72 GMC (Ratikle),
back in November of 2011.
I don't visit the site much anymore,
but please feel free,
to drop me a private message.
RIP...."RATIKLE"
wwotr is offline   Reply With Quote
Old 03-02-2011, 12:58 PM   #17
es67chevy
es67chevy's Avatar
Thanks, VetteVet. Those pictures helped me find the ones we needed that I took. I obviously wasn't focusing on this piece, but I can clearly see it plugged into my old rat's nest of a wiring harness. The truck just never had a horn so didn't realize this is what that was for. Plus, these pics were taken over two years ago so the memory is a little fuzzy!
Eric
1967 C10 SWB
383 Stroker/TH400
Surf Blue Paint
Old 03-02-2011, 12:59 PM   #18
es67chevy
es67chevy's Avatar
Like 2AM!
Man, that would suck!! I'd have probably pulled the horn right off its mounting point and chunked it across the garage!!!
Eric
1967 C10 SWB
383 Stroker/TH400
Surf Blue Paint
firewall
