Old 05-13-2021, 07:46 PM   #1
Don D
Automatic Tilt Steering Column
Automatic Tilt Steering Column that is now a truck steering column converted for a motor home. The neutral safety switch was moved to the correct location on the column for a truck & the hole where the neutral safety switch was is filled back in. The offset in the shift lever arm has been taken out made to look like a truck. The column was cleaned & stripped & checked for worn or broken parts & replaced if necessary. The column was painted semi-gloss black. The turn signal switch & wiring harness was in good shape so it was reused & a wire adapter was installed so it plugs in the truck wiring harness. The bearings were all greased. Has new turn signal & tilt levers, new upper& lower rubber seals & correct truck firewall seal retainer, & new shift indicator pointer. The shift lever is used but in good condition. Ready to bolt into a truck. $ 395.00 Shipped / No Shipping to Alaska or Hawaii / Postal Money Order or Personal Check
Don D is offline   Reply With Quote
Old 05-14-2021, 08:10 AM   #2
Boe3
Re: Automatic Tilt Steering Column
I will take it. Let me know where to send the check.
Boe3 is offline   Reply With Quote
Old 05-14-2021, 12:01 PM   #3
Don D
Sold / PM sent
Old 05-15-2021, 04:09 PM   #4
Don D
Originally Posted by Don D View Post
Sold / PM sent
Hi Rich, I sent you a PM with my info. yesterday, did you get that ok?
Let me know, Thanks Don
Old 06-01-2021, 01:04 PM   #5
Boe3
Hi Don, I received the packages. Great job on the column and the packaging to get it to me. You put together a great product! Much appreciated. -Rich
Old 06-01-2021, 02:42 PM   #6
jjzepplin
jjzepplin's Avatar
Nice looking column.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 06-01-2021, 04:12 PM   #7
Don D
Thanks Rich, I am glad everything finally got to you & you are happy with your purchase, Don
