Old 06-06-2016, 09:50 AM   #1
pointer80
pointer80's Avatar
no brights but turn signal indicators on dash light up
Hi all, I just purchased a 1993 chevy 1500 and trying to work the bugs out. When I turn on the bright lights on the indicator on the dash comes on and also both turn signal indicators on the dash also come on but no bright lights? Any ideas? Thanks guy's
pointer80 is offline   Reply With Quote
Old 06-07-2016, 12:36 PM   #2
sntrym95
sntrym95's Avatar
Re: no brights but turn signal indicators on dash light up
I would start with the wiring harness from the column to the connector under the dash. Make sure no one hacked it up of left half of an alarm system in there. Also, check the ground. Then I would move onto the turn signal switch. You may have a short or bad connection in there.
Mike
sntrym95 is offline   Reply With Quote
