12-06-2016, 04:28 PM | #1 |
Alright Alright Alright
Roadside fuel pressure regulator help needed.
I'm helping a friend get a P30 chassis 1984 motorhome down the road and we have run into a huge problem. It's a 454 with a quadrajet that I rebuilt yesterday. It has an electric Carter fuel pump in the rear and a brand new mechanical pump on the motor. The carb is being inundated with fuel as its coming out of the top of the carb. We stopped by a parts store and got a cheap spectre pressure regulator. It doesn't work, filled a water bottle up in a few seconds on the lowest setting. I tore the carb back down, lowered the float to 3/8 below the carb body. Even with the mechanically pump bypassed, it still floods the carb. We're thinking of bypassing the electric pump and seeing if the mechanically pump candidate get fuel to the front. Any suggestions?
1972 Cheyenne Chevrolet red and white 357ci, Vortec heads, GM Performance high rise intake, Comp 268H .454/.454 218/218 110 LSA Quadrajet carb, Flowtech headers, 2.25 40 series HEI, Curve kit, TH 350, 3.07 gears 275/60/15s on 15x8 rallies |
12-06-2016, 05:22 PM | #2 |
Re: Roadside fuel pressure regulator help needed.
Did you hang the needle clip on the float correctly?
Common flooding problem if not done right. Like in here. http://www.crankshaftcoalition.com/w...4MV_carburetor |
12-06-2016, 05:29 PM | #3 |
What pump did you put in? Got a part number or link? Specs?
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
12-06-2016, 05:43 PM | #4 |
I removed the clip. I run all of my quadrajets that way. If I put it back on, how does it go?
12-07-2016, 02:04 PM | #5 | |
*** That's interesting ***
I do agree that you may have a needle and seat problem.
Tom Chevy by day... 1969 Chevy C30 Rollback Tow Truck -- 383 stroker, 4L80E 2011 Chevy Caprice PPV 9C3 6.0L 1995 Chevy Caprice 9C1 1994 Chevy Caprice 9C1 #3 1995 Chevy Caprice Wagon #2 1995 Chevy Impala SS Mopar by night... 1969 Dodge Charger 1972 Chrysler Newport 2dr Hardtop (27K miles) Plus others... |
12-08-2016, 01:44 AM | #6 |
Turns out, there was an unseen sliver of aluminum in the seat. Removed it and it runs like a top. Thank you guys for the help.
