Old 06-03-2022, 08:17 PM   #1
Backpayne
Clicking in the engine - Where would you look?
I have an Olds 455 in my '64 and it has developed a clicking/clacking when I accelerate and rpms are above 2000. Engine oil was metal free as was the Wix filter media, thankfully. I'm in the process of readjusting the roller tip rockers. I've retightened the exhaust manifold bolts and they were good. I'll be checking the flexplate bolts, too.
What else should I be looking into? Can roller tip rockers be loud?
Backpayne is offline   Reply With Quote
Old 06-03-2022, 08:43 PM   #2
RustyPile
RustyPile's Avatar
Re: Clicking in the engine - Where would you look?
Diagnosing noises over the internet is at best, difficult.. "Clicking/clacking" when accelerating.. What happens when the speed levels off?? What you're hearing could be detonation or pre-ignition from excessive ignition timing or compression for the gasoline octane.. Also, could be carbon buildup causing hot spots that pre-ignite the charge. Before you go charging down a rabbit hole, I suggest you take an experienced mechanic for a ride and let him listen to the noise.
RustyPile is offline   Reply With Quote
Old 06-04-2022, 07:36 AM   #3
Dead Parrot
If the intake manifold has an exhaust crossover, check those places. Old exhaust gaskets can leak even if the bolts are tight. Check further down along the exhaust system. Your description of noise during more foot in throttle is consistent with an exhaust leak.
A dying power steering pump can mimic engine noises.
Dead Parrot is offline   Reply With Quote
Old 06-08-2022, 11:15 AM   #4
bhap
bhap's Avatar
Smile Re: Clicking in the engine - Where would you look?
My 1970 Olds had a lifter that would stick under acceleration .. is it a click or a clack??
bhap is offline   Reply With Quote
Old 06-08-2022, 01:19 PM   #5
geezer#99
geezer#99's Avatar
First thing I would do is check the timing and pull it back 4 degrees.
That might be detonation you’re hearing.
