Old 10-09-2021, 11:06 PM   #1
toymanbob
Old bed wood needed
The wood in my '55 long bed is mostly good, I'd like to keep it. There are two or three boards that should be replaced but I don't want new wood. I'm in Oregon but driving to Mesa Az for the winter and could stop on the way if anyone wants to sell me a few used slats. Thanks, Bob
toymanbob is offline   Reply With Quote
Old 10-10-2021, 01:46 AM   #2
mr48chev
mr48chev's Avatar
Re: Old bed wood needed
You can probably find some old straight grain yellow pine boards that have the proper aging that you can just trim and cut the grooves for the strips and by spring they will look like the rest of the wood in the bed.
My ongoing truck projects:
Old 10-10-2021, 09:37 AM   #3
Rickysnickers
I'm sure, around your parts, there are lots of old barns where you could get a few pieces.
Old 10-10-2021, 07:34 PM   #4
MiraclePieCo
MiraclePieCo's Avatar
You can artificially age new wood with a mix of vinegar and steel wool. Let 00 steel wool dissolve in vinegar a couple of days, then wipe on the wood. Let it sit overnight to see how dark it is before adding any more, then repeat as necessary to achieve a close match.
1951 Chevy Panel Truck
MiraclePieCo is offline   Reply With Quote
Old 10-10-2021, 09:18 PM   #5
toymanbob
Now that IS GOOD ADVICE! I'l give the aging process a try, thanks.
Old 10-18-2021, 12:26 PM   #6
_Ogre
_Ogre's Avatar
sand blasting will make new wood old fast
combined with vinegar & steel wool might be what you want
shop air compressor timer
Old 10-19-2021, 03:19 AM   #7
MiraclePieCo
https://www.familyhandyman.com/list/how-to-age-wood/
Old 10-19-2021, 09:31 AM   #8
my56chevytruck
my56chevytruck's Avatar
I've done this, it works well.
RUBBER DOWN AND HIT THE ROAD!!!
1940 Ford Dlx Coupe
1969 Mach1
my56chevytruck is offline   Reply With Quote
