03-02-2021, 10:20 PM | #26 |
Re: Refreshing the Fontend 72 C10
Just a thought, how old are your shocks. Your going to have them off anyway. I call this sensous. Sensous are already doing it. You might as well replace ..... LOL
03-04-2021, 12:09 PM | #27 |
Mr. Cheyenne
My new KBY's come in today, so I am doing them 1st. Though my fronts appear to be originals, with the frame stud in the upper shock. So I am all worried about getting this off being at 150 ft lbs and then getting the new supplied KBY stud on @150 ft lbs. On the passenger side, I think it is the EEC fuel lines running real close to that frame nut.
Richard '72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT SBC 350 | TH350 | LWB | AC | Buddy Seats Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim |
03-18-2021, 12:05 PM | #28 |
I just came across this thread again and remembered something I forgot to mention previously. While you're doing the front end refresh, you should really replace the lower a-arm u-bolts. The original ones were 7/16" or 1/2" and are prone to snapping when reversing with the wheel turned to full lock in either direction. The Dorman 13503 are the ones you want to get. They're a thicker 9/16" and will not snap like the stockers can.
72 C10 lwb fleetside -stock 350/350 combo |
04-06-2021, 01:24 PM | #29 |
Mr. Cheyenne
Okay, I just about have all my parts from RockAuto.
What is the best way to paint these guys black? 1. degrease / clean the new parts 2. I assume any old rust-oleum 3. rust-oleum Black - Semi or Stain? I wouldn't think high-temp rust-oleum would be needed for frontend parts .... PS: darn it forgot the Dorman UBolts!
04-06-2021, 01:45 PM | #30 |
Mr. Cheyenne
I found this, should be good enough for these little parts on the front end.
VHT ESP671007 Satin Black Roll Bar and Chassis Paint Can
04-06-2021, 05:31 PM | #31 |
Yes, clean off any surface rust and degrease the parts. After clean, I spray them off with some brake cleaner and then you can start painting. I used the VHT paint too. I sprayed 4 coats on mine.
04-06-2021, 06:31 PM | #32 |
Of all the tasks rebuilding the Arm Shafts will be the most difficult to do.
One needs a 1-5/8" socket or something that opens up that large. I have seen pipe wrenches and 16" crescent wrench work but it's not pretty! Best off to brake the large nuts loose while they are still on the truck. Most people don't have a vise and table heavy enough to get them apart. Don't forget to mark the alignment shim location. Best of luck on your project. Rick |
04-06-2021, 06:39 PM | #33 |
Mr. Cheyenne
Thanks guys!
04-06-2021, 07:12 PM | #34 | ||
"I ain't nobody, dork."
All Moog here too for a complete front end rebuild on my 1972 GMC C15. But I didn't order them online and have to wait. My local auto parts store had everything on the shelf. So I got it all the same day. Plus if something was wonky, I could return it to them and not have to ship it back.
Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
04-21-2021, 12:20 PM | #35 |
Mr. Cheyenne
Well, got the truck back to today, though I could have gotten it yesterday if I was in town (three and 1/2 days work). I was in Dallas watching the Stars kick the Red Wings ass at the American Airlines Center in a VIP box (a friend 4 won VIP box tickets).
I bought almost the parts from RockAuto.com, plus front/rear rubber brake lines and the CPP Front sway bar from Summit. The ran into problems, mainly getting things disassembled and then the rear bleeder was all kinds of clogged but none of the rear brake parts needed replacing, was told I don't need to even think about the brakes for a long time/many miles. My God, the difference is night and day and that is a understatement! Even pulling out of the shop's parking space I notice the difference (nice stiff / non-boating steering). I then noticed the difference on how she drove on the potted crappy road. Then I got to turn about circles and s-turns where before I would take them slow but now plow through them at 30~40 mph (before at or way under 20 mph). So while they ended up blow past my high cost number, it was actually worth it. 1.5k to install the below (I came into the shop with all the parts below, in hand). x1 Pitman Arm MOOG K6131
Richard '72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT SBC 350 | TH350 | LWB | AC | Buddy Seats Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim Last edited by Rich72C10; 07-21-2021 at 01:09 PM. |
07-22-2021, 04:43 PM | #36 | |
70+ ( Old Skool Club )
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
07-23-2021, 07:07 AM | #37 |
Mr. Cheyenne
I was bummed I couldn't get the matching Moog Lower Control Arm Shaft but no one had it in stock, I waited a bit for it to show up back in stock but in the end I got the MEVOTECH. I thought about replacing the Steering Box too but the rest of that all seemed to be in good order, so I left that alone. Those parts are the only "old" parts left in the steering path, as last year I put in a shorten tilt column in.
I have bounced around in my head about getting a rear sway bar but it doesn't seem as cut and dry as it was with the front one.
07-23-2021, 09:18 AM | #38 | |
07-23-2021, 10:54 AM | #39 |
BlahBlahBlah
Timely thread, good info ... Thanks!
… … … … … … … … ... … … … … … … … … … … … Monroe Swap meet May 18-19. Mike has the same spots for the NW guys he's had forever. Lunch time BBQ at the spaces. If you have stuff to sell bring it along. If you have a question PM stllookn (Mike) here via the board. https://67-72chevytrucks.com/vboard/...d.php?t=851291 |
07-23-2021, 04:53 PM | #40 |
I went with all MOOG from Jegs a couple of years ago, everything except the lower ball joints and lower control arm shaft kits was around 250 shipped.
I had already done the ball joints and shafts with Moog. Moog has the stuff! All Made in USA! |
