Old 10-18-2022, 08:47 PM   #1
Baketown Scotty
Junior Member
Baketown Scotty's Avatar
SM465/ Bellhousing Mounting
1966 GMC Suburban 4x4. My NP540 transmission was leaking badly and I was unable to find bearings and seals to fix that. I have a SM465 that I was planning to install. The bellhousing for the NP540 has two mounting spots to bolt to the crossmember but the bellhousing for the SM465 does not. How do I mount the SM465? In the picture the bellhousing for the SM465 is on the left and the one for the NP540 is on the right.
1964 Chevy Suburban 4x4
Baketown Scotty is offline   Reply With Quote
Old 10-18-2022, 09:20 PM   #2
Wrenchbender Ret
Re: SM465/ Bellhousing Mounting
You need a bell housing for a 68-72 truck that had an SM 465 trans. The center hole is larger then one from a SM 420.
George
Wrenchbender Ret is offline   Reply With Quote
Old 10-18-2022, 11:56 PM   #3
Baketown Scotty
Junior Member
The one I have has the 5-1/8” opening. It’s the mounting I’m having a problem with.
Old 10-19-2022, 02:09 PM   #4
Wrenchbender Ret
You have the alum. housing that was used from 73 on up. It used a mount on the rear of the trans. You need the cast iron BH with the 5 1/8 hole used with sm465 68-72. It has the mounts on the bottom of the BH. I have heard of guys boring the one with the smaller hole out to 5 1/8.
George
Old 10-20-2022, 04:30 PM   #5
Baketown Scotty
Junior Member
Thank you George. Took awhile for it to soak in. I was sold the wrong one a long time ago, how could that be? Thanks again.
Old 11-18-2022, 08:30 PM   #6
crazy longhorn
Fabricate till you "puke"
Just a thought.....if your bell Cast bell does not measure the same as the input coller......pretty sure it wont, as posted. 68-up had the 5.125 hole, whereas 67 back had a 4.687 hole. The easy way would be tho swap the cast bell(40 dollar part), or my thoughts would be to take the bearing retainer to the machinist...chuck it in the lathe& trim the OD to spec? just a thought Longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
