01-23-2017, 04:46 PM | #1 |
tire/wheel size on 2wd blazer
Building a 2wd Blazer with 4/6 ECE static drop, going to run 255/40/20 and 295/40/20
1st time I've ventured outside a 15in tire and wheel, what size rims and backspacing is working the best on this setup? Thanks Guy's Donnie
Things happen for a reason! |
01-23-2017, 06:01 PM | #2 |
Re: tire/wheel size on 2wd blazer
I have 20x10 with 5.5" BS& 20x8.5 with 5.25" BS. They fit perfect. I've got the same size tire you're planning to run.
01-23-2017, 08:31 PM | #3 | |
No rubbing issues?
01-23-2017, 08:36 PM | #4 |
Front about 3.5" sidewall. Rear about 4" tires are right at the bottom of fender if not tucked slightly. Absolutely no rubbing. I'm lowered 4.5" up front and roughly 6.5" out back.
01-23-2017, 08:41 PM | #5 |
I will be coping yr setup, well maybe a different wheel, not that yrs don't look good! lol
Thanks again.....
01-23-2017, 09:20 PM | #6 |
No problem. Good luck.
11-28-2022, 08:49 AM | #7 |
Carpe manana
Ttt
12-06-2022, 07:06 PM | #8 |
Thank you so much, that's what I needed.....
I would had never found that.
