11-17-2014, 04:12 PM | #1 |
Poppa Smurf needs rust repair...
My 68 C-10 needs front and rear cab supports and inner & outer rockers. My question, is should I replace them one at a time or replace whole floor pan? Just kinda worried about cab flexing with floor removed and the fit of the floor pan. Thanks Kirk..
Kirk Myers 68 chevy swb owned since 87, under the knife 71 skylark 9.20's @ 76mph 1/8 mile |
11-17-2014, 08:15 PM | #2 |
Re: Poppa Smurf needs rust repair...
Replace the whole floor pan. It will look better instead of all patched up.
1971 Cheyenne Super - Factory Big Block - Second (1987-89) & Fourth (2014-) Owner - To be restored 1978 Turbo Malibu - Owned since 1986 1987 Grand National Aerocoupe -1 of 1 1988 LeSabre T-Type - Supercharged |
11-17-2014, 08:53 PM | #3 |
Dan Johnston
Depends on how talented you are... I had the entire floorpan in my 67 replaced... it cost me 900.00 in labor...
Dan Johnston... Owner of My Dad's- '67 Chevy C-20 Custom Camper Short Fleetside Pickup PAPA J And our newest addition a- '71 Chevy CST/10 Short Fleetside Pickup Haulin' SOLD Papa J's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=612847 Haulin's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=671130SOLD B Bears Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=744210 |
11-17-2014, 09:34 PM | #4 |
that was a good price
11-18-2014, 12:15 AM | #5 |
All about them K’s
I disagree, unless the main floor has a ton of rust. I've done a couple complete floors in these old trucks and it's a lot of friggen work. Not to mention it can be tough to get the aftermarket floor fit and finish just right. Floor supports, rockers and cab corners are all pretty easy on these trucks if you take your time and make sure everthing fits and lines up right before you weld it solid. No sense in replacing the whole floor if only the areas you mention are shot. Just my opinion, probably not worth much...
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 |
11-18-2014, 12:58 AM | #6 |
Moderator
If the rest of the floor is good, I'd just repair the rusted areas. A picture would be nice, however.
2018 Chevy Crew Cab 2006 Impala SS 1965 Plymouth Sport Fury 1970 Chevy Longhorn
70 Longhorn CST Build Adding an AM/FM Decal |
11-18-2014, 10:10 PM | #7 |
Thanks for the replies, pics coming soon (once I figure it out). Cab is off the frame and mounted on a homemade rotisserie. If I do the complete floor pan, which brand do I use, Dynacorn, AMD, LMC ??? Thanks again Kirk...
11-19-2014, 07:05 AM | #8 |
Dan Johnston
I would recommend the Dyanacorn... it fits really nice...
11-19-2014, 07:40 AM | #9 |
Anything but LMC ( Lots More Crap from China).
11-19-2014, 09:46 PM | #10 |
11-23-2014, 10:45 PM | #11 |
Kirk Myers 68 chevy swb owned since 87, under the knife 71 skylark 9.20's @ 76mph 1/8 mile Last edited by kamkam1; 11-23-2014 at 11:00 PM. |
11-23-2014, 10:58 PM | #12 |
11-24-2014, 07:30 PM | #13 |
11-24-2014, 07:33 PM | #14 |
11-24-2014, 11:10 PM | #15 |
Nice work Elliot949, did you also replace the bottom of the a- pillar on both sides ??
11-24-2014, 11:17 PM | #16 |
Dan Johnston
Yes we did... lots of work and it came out great... starting with the Dynacorn floor made it alot easier...
