Old 01-30-2021, 10:44 AM   #1
03BlkZ
Radiator question
Im.looking for a radiator for my 70 C10 truck. The one that came out was a 4 core but im not finding much online for a replacement. All I find in 2 and 3 row. Or they have transmission cooler ports. I guess I could just plug the ports. Thoughts? I'm getting closer to firing the engine and this is one of the last things I need.
03BlkZ is offline   Reply With Quote
Old 01-30-2021, 11:19 AM   #2
pjmoreland
pjmoreland's Avatar
Re: Radiator question
I don't have any personal experience with this product, but NPD has a 4 row radiator listed on their site.
https://www.npdlink.com/product/radi...1969&year=1969
pjmoreland is offline   Reply With Quote
Old 01-30-2021, 11:28 AM   #3
03BlkZ
I would like an aluminum radiator but this is definitely an option. Thanks!
Old 01-30-2021, 11:33 AM   #4
Rickysnickers
Most AL radiators you find will only be 2 or 3 rows cores. They are more efficient than brass/copper radiators hence the need for less rows. The rows also also a bit large in the AL radiators as compared to the brass/copper type.
Old 01-30-2021, 11:37 AM   #5
Lee H
Lee H's Avatar
Check out RnD Fabrication, I'm running 3 of them, one is 10 years old.
http://www.rndfabrication.com/CrossflowRadiators.html
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 01-30-2021, 12:02 PM   #6
03BlkZ
Dude those look nice! I don't see any options or information on what row they are but it say drop in. I may pick one of these up. How long does it take to receive after ordering?
Old 01-30-2021, 12:08 PM   #7
Grumpy old man
Grumpy old man's Avatar
A lot of guys are using a Champion CC369 and they are on sale for $214.98 + .
the CC369-M comes without the auto trans line ports - https://www.championradiators.com/product/CC369-M
https://www.championradiators.com/pr...iABEgLGcfD_BwE
Skilled labor isn't cheap , Cheap labor isn't skilled
Old 01-30-2021, 12:41 PM   #8
Lee H
Lee H's Avatar
In a covid environment I don't know. Call and ask, very friendly people. The owner, Sparky, usually answers the phone.
Old 01-30-2021, 02:39 PM   #9
Andy4639
Old member
Andy4639's Avatar
Talking Re: Radiator question
Here is a thread I did on mine a few years ago 2015 when I bought the aluminum one for the 71. I have one in the ramp truck, 64 SS Impala and had one in my 56. Not one problem out of any of them. The 71 with LS 6.0 never cuts the fans on unless I'm sitting still for a period of time. No plastic and all tig welded.
http://67-72chevytrucks.com/vboard/s...=681849&page=2
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 01-30-2021, 03:17 PM   #10
Stocker
20' Daredevil (Ret)
Stocker's Avatar
My K20 has an all-metal 4-row I bought many years ago.
If / when it needs replacing, I'll take a good long look at 2-row radiators.
Food for thought:
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 01-30-2021, 04:38 PM   #11
Grumpy old man
I found the 2 row mentioned above , Its currently out of stock . $247.00
http://www.speedcooling.com/1967_197..._Radiator.html
Old 01-30-2021, 05:44 PM   #12
dmjlambert
dmjlambert's Avatar
That's the one I have, Grumpy old man.
Old 01-30-2021, 06:08 PM   #13
Grumpy old man
How did it work for you ? Stock fan shroud ? radiator mounts?
Old 01-30-2021, 08:00 PM   #14
Sheepdip
Sheepdip's Avatar
......X2 on the Champions.... I have 3 with zero issues, one is about 20 years old now. FYI Ledfoot Racing owns/is Champion Radiators.
Sheepdip is offline   Reply With Quote
Old 01-30-2021, 08:21 PM   #15
dmjlambert
dmjlambert's Avatar
Yes it fit fine. The shape where it fits into the support bracket is a little weird, but it works fine. I am using the original shroud that I recently restored with new upper mount ears because they were broken off; I used the super glue and baking soda method you recommended. There is about a 1/4 inch gap along the top of the radiator to shroud and I don't know if that would be different with the stock radiator. The gap has not bothered me. I sold that original 4-row radiator to another board member a few years ago, and at the time I was using the old radiator the shroud had broken ears so I don't know how it would have fit at that time. My new Engineered Cooling Products radiator is now about 4 years old.
Old 01-31-2021, 12:02 AM   #16
rechinca
rechinca's Avatar
Cold Case aluminum radiator. Stamped tanks and it looks just like the original. Good quality and fits like it should in the factory big block mounts due to size
1971 Custom/10 - 350/3 speed, Orange/White roof
rechinca is offline   Reply With Quote
Old 01-31-2021, 06:01 AM   #17
03BlkZ
I was wondering about cold case. I see it is a two row but they say they cool better than an old 4 row. Anyone else using one?
Old 01-31-2021, 07:18 AM   #18
03BlkZ
Thanks for all the replies. I decided to go with a cold case. All the reviews seemed positive pluse my summit store has it in stock 100 miles away. Should get it very quick. Thanks again!
Old 01-31-2021, 07:41 AM   #19
GMC72BB
Junior Member
GMC72BB's Avatar
I didnít See the post before your purchase, I have the Cold Case and I have a BB, in my Gmc, plus I live in Florida, very pleased with it so far, Iím still running the factory fan shroud as well,
GMC72BB is offline   Reply With Quote
Old 01-31-2021, 08:48 AM   #20
03BlkZ
Awesome! Good to know. I was wondering if I should run a shroud or not. My dad daily drove it for 30 years and it never had a shroud. I guess adding one could only help the cooling abilities.
Old 01-31-2021, 08:59 AM   #21
rechinca
rechinca's Avatar
I think you will be very happy with the product. Granted itís winter here so no chance to drive it in warm weather, but I am trusting it with my new crate engine and the was perfect. You will need the big block mounts though and use the outer holes. I shaved down the rubber isolators a bit. I am running my 3OTT so I just plugged the holes for the auto trans cooler. But fit and finish as well as the packing were excellent.
Old 01-31-2021, 10:15 AM   #22
tim_mc
tim_mc's Avatar
Another vote for the Champion CC369. It always runs cool. I had to use the heavy duty (wider) rubber mounting pads for the thicker core. I use a standard 4WD shroud since my SBC is in the back (4WD) position. Sounds like the Cold Case is a quality unit too.
For the fan I have a Derale 17118 6-blade 18" rigid fan and a Hayden 2705 thermal fan clutch w/clockwise rotation. This set up works great and fits nicely inside the shroud if you're not going with electric fans.
1967 C20, 350 SBC w/roller cam, 700R4, PS, 4-wheel PDB, Old Air AC & Tilt column.
tim_mc is offline   Reply With Quote
Old 01-31-2021, 11:29 AM   #23
Stocker
20' Daredevil (Ret)
Stocker's Avatar
I was wondering if I should run a shroud or not..... I guess adding one could only help the cooling abilities.
Yes, absolutely run a shroud. In fact, if you don't have a closed system with a coolant recovery tank, I would add that also.
And as noted above, a 6- or 7-blade fan on a heavy duty thermal clutch. If you think I hate overheating..... you're right!
- Mike -
RIP El Jay
Old 01-31-2021, 11:49 AM   #24
Grumpy old man
I have a 6 blade fan with the Hayden 2705 clutch with a shroud , I think I'm going to order the champion CC369-M and see how that set up works .
Copyright ©2000 - 2021, vBulletin Solutions Inc.
Copyright 1997-2020 67-72chevytrucks.com
