Old 08-08-2021, 04:06 PM   #1
crazy longhorn
Fabricate till you "puke"
toe in with my 69?
Ok, I do not have an issue with toe....1/8 in, with the wheels straight. I can center the steering box, no issue. My understanding, is that the box needs to be centered, with the wheels straight? In an old country boy shop, how do you make sure that the wheels are straight? Is it a mater of measuring the tie rods, left vs right, for the figure.....or a better way? longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 08-08-2021, 08:21 PM   #2
mongocanfly
mongocanfly's Avatar
Re: toe in with my 69?
what i did on mine was rotate the steering box from lock to lock...(i think it was 3-1/2 turns)...then divided that by 2 ( 1-3/4 turns),rotated it back that much from full lock..then adjusted the drag link until the tires were pointing straight
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 08-09-2021, 11:10 AM   #3
SCOTI
SCOTI's Avatar
x2. That pretty much covers it.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 08-09-2021, 03:13 PM   #4
68 P.O.S.
Here's a quick article on it: http://www.powersteering.com/blog/20...x-is-on-center
72 C10 lwb fleetside -stock 350/350 combo
68 P.O.S. is offline   Reply With Quote
Old 08-09-2021, 04:49 PM   #5
crazy longhorn
Thanks guys, I think its pretty straight forward on the center up.....& a pic was worth 1000 words 68 From that point, I will assume that it is just a matter of keeping the LH &RH tie rod assys to the same lenght , while setting the toe? longhorn
Old 08-09-2021, 06:11 PM   #6
SCOTI
SCOTI's Avatar
Each side should be similar in length.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 08-10-2021, 03:46 PM   #7
The Rocknrod
Moderator
The Rocknrod's Avatar
I did the same thing.
Just had mine aligned and they used the arc/degree BS their all doing now.
Anyway I went home and checked it had 1/16" toe in. Did a slight tweek and now have 1/8".
Drives better on these terrible roads around here (farm to market) but on good roads it's great for what it is.
Old 08-10-2021, 05:37 PM   #8
crazy longhorn
Thanks again to ALL....yes I do agree to the 1/8 inch toe in . At speed, & I should not say (about 2 1/2 times the legal limit of 55) The toe will let em run straight @ speed. One more ? The old truck has a 84 Burb box (variable ratio), & is fitted with a 5.3 LS/& steering pump. Do you guys think that the pump, that was set up for that rack& pinion, is to touchy for the old steer box? Longhorn
Old 08-10-2021, 07:23 PM   #9
SCOTI
SCOTI's Avatar
It appears to be subjective. Some are more 'in-tune' w/their set-up & thus are more sensitive to the feel of things. Others don't notice much (if any) difference.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
