Old 09-23-2015, 06:59 PM   #1
merlin3
starter hanging up
on my big block c10 2wd my new starter was engaging but it would hang up on the flywheel,i thought it was a bad reman starter but when i installed the new summit mini starter i pulled the gear out by hand,meshed the teeth together to check the tolerance on the pinion i noticed the gear on the starter won't spring back and when i pulled the old starter i noticed the starter gear was hung up on the flywheel,any ideas what is wrong? thanks.[ i did not shim the first starter]
merlin3 is offline   Reply With Quote
Old 09-23-2015, 07:40 PM   #2
tdangle
tdangle's Avatar
Re: starter hanging up
Due to tolerances in the case, you may need to shim this one. If I remember correctly, when my dad bought the truck new in 70 he had similar problems that the dealer spent many visits trying to fix.
Terry
1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC
tdangle is offline   Reply With Quote
Old 09-24-2015, 04:49 AM   #3
merlin3
i did shim it,used 1,2,3 shims plenty of clearance with the pinion and flywheel and it still gets stuck on flywheel,thanks
