11-13-2014, 12:06 AM | #1 |
Good 6 lug replacement rear for a TF?
Like the title says, what is a good replacement 6 lug rear axle for a 55-59 1/2 ton?
11-13-2014, 01:17 AM | #2 |
Re: Good 6 lug replacement rear for a TF?
What would make an axle best? late '80s to early '90s Toyota 4wd V6 trucks have a six lug pattern that matches the original, plenty of strength, and are close in width.
11-13-2014, 03:26 AM | #3 |
67-69 c10 are 1/2" wider wms to wms and take a 1310 u joint
GOD BLESS AMERICA! |
11-14-2014, 09:29 PM | #4 |
If you've got the bucks and need the strength, I think the recipe for a 14 bolt is to use the C&C 14 bolt & Solid Axle Industries hubs. Should get you down to 62-63" WMS-WMS - but this might be gross overkill for your application.
The 12 bolt is probably a better, more reasonable bet.
"Over my head" 1957 Chevy 3200, big rear window & 6 lug. Front disc, power steering, Vortec 4.8 / 4L60E swap, hydro boost brakes & patina. |
11-14-2014, 10:19 PM | #5 |
The C-10's of those years had coil springs on the rear while most of the GMC half tons ran leaf springs making one from GMC an easier swap.
You might look at a 2010 to 12 or 13 Chevy Colorado 4x4 which has a 59.8 rear track width. They probably aren't inexpensive though.
11-14-2014, 10:36 PM | #6 |
Most of the 67-68 GMC's leaf spring rears were Dana 44's, most had 3.54 gear sets..
11-15-2014, 04:03 AM | #7 |
Torched the angled coil perches off and welded some 2" new ones when I did mine. Worked great.
11-16-2014, 01:52 PM | #8 |
I have a 65 GMC pickup leaf spring rear in my '57.
It is a Dana 44 and had 3.54 gears. Evidently, the rear sat for along time and had rust on the gears so I had it rebuilt with new gears, a new trac-lok posi and all the bearings. Stayed with the 3.54 but other ratios are available. The spring perches need to be moved inward just a tad but the width is perfect. Finding brake drums for it was a challenge. I ended up buying brake drums for a Jeep waggoneer and having the center holes enlarged at a machine shop. The lug holes have to be drilled out to 9/16" from 1/2" too. Fit perfect now. Another issue is E-brake cables. The ends are different at the backing plates. Either have to get custom cables or modifiy the brake backing plates. I did the latter. |
11-17-2014, 08:58 PM | #9 |
I have a C10 rear with leaf spring pearches welded on for TF trucks, 100.00 in central florida.
1959 short fleet Camaro clipped, Shockwaves, Strongarms, Musclebar, 4 link explorer rear. LY6 6.0 and 6l90. Current project. 1958 50th Anniversary Golden Jubilee next project |
