11-22-2021, 08:53 PM | #1 |
Just here to tinker
Stumped on Fuel Gauge
Hi folks,
I used to think I was pretty decent at solving electrical gremlins, but this fuel gauge in my '86 is kicking my butt. It all started this summer when the gauge would only read 1/4 tank when it was full. This happened out of nowhere as it always worked before. It would move to E as you used fuel, i.e.: 1/8 tank would actually be 1/2 tank or so. I thought that was weird so I pulled the sender wire and put it directly to ground to test the gauge. That pegged the gauge out so I thought OK, bad sender. I pulled the tank and replaced the sender. before I put the new sender in the tank, I hooked it up to the sender wire and ground and manually moved it and watched the gauge respond. OK, all good? Then I put the sender in the tank, installed the tank and added 6 gal of gas or so. The gauge will not come off of E. If I ground out the sender wire, It will peg full as before. I rechecked all grounds from sender to frame, frame to battery, battery to body, etc. All are 1ohm or less. Any one have any ideas of what I am not doing correctly here? Thanks in advance, Cort
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(winter unit)https://67-72chevytrucks.com/vboard/...25#post8900725 |
11-22-2021, 10:35 PM | #2 |
Re: Stumped on Fuel Gauge
My first guess would be that the float had a hole in it or it is hung up on something.
1972 GMC Jimmy 4x4 LS Swap 1985 Chevy K20 1994 GMC Yukon 2021 GMC 2500HD Duramax AT4 My "It's a Jimmy Thing" Build http://67-72chevytrucks.com/vboard/s...d.php?t=583528 Budget Build 1985 K20 http://67-72chevytrucks.com/vboard/s...d.php?t=801565 |
11-23-2021, 07:55 AM | #3 |
Just here to tinker
That’s what I was a feared of. Now I get to pull the tank again…ggrrreeeaaatttt. Haha.
11-23-2021, 09:21 AM | #4 |
Had something similar on my 84 CUCV. Gauge would only rise to 1/8 when full but would read E when empty. Saw a thread on the Steel Soldiers site on a similar problem that stated replacing the gauge fixed the problem. Swapped in a different gauge and that one worked normally. Only downside is it says Unleaded instead of Diesel.
It was an easy fix at the time as I had the gauge cluster out chasing issues with several of the idiot lights that were standard with the CUCV trucks. Never checked what happened if I grounded the sender wire. The SS thread stated that one of the resistors failing in the gauge can cause that behavior. |
04-09-2022, 02:21 PM | #5 |
Just here to tinker
Alright fellas, I need some help here. I’ve swapped two senders, two gauges, ohm’d out the sender wire, checked all grounds. I’ve manually moved the sender by hand and watched the gauge respond. When I first start the truck for the day, the gauge reads correctly, but when the engine gets warm, the gauge goes back to E….
I’ve troubleshot a lot of wiring issues in my time, but I’m stumped. Only thing I can think of is something is heating up and causing resistance to change. What could it be?
04-09-2022, 06:56 PM | #6 |
Where did you ohm the sender wire from? All the way to the gauge cluster?Possible getting resistance in the bulk head connection? I would probably start by running a temporary new wire from the sender all the way to the cluster. If that doesn’t solve it then you narrowed it down to the printed circuit on the gauge cluster.
04-09-2022, 07:16 PM | #7 | |
Just here to tinker
04-10-2022, 06:28 PM | #8 |
The gauge topping out at 1/4 even when the tank is full and the sending unit & float are okay is often a sign that the resistor on the back of the gauge is bad or not making a good connection.
04-10-2022, 06:47 PM | #9 |
Just here to tinker
Ok thanks for that. At this point it has to be something I’ve already touched since I literally have touched everything. Haha. Maybe the little spring clips in the circuit board did not get seated well enough.
